Bruce Ferguson
Vectorworks, Inc Employee-
159 -
Reputation
12 GoodPersonal Information
Location
United States
Recent Profile Visitors
Nemestschek- please protect my serial #
Bruce Ferguson replied to Amorphous - Julian's question in Wishlist - Feature and Content Requests
I would think it would sometimes be useful to see the serial number. Perhaps it should be hidden by default, and have an option to make it visible?- 1 reply
- 1
what determines a DLVP's position in the design layer
Bruce Ferguson replied to rexwexford's topic in General Discussion
In my earlier comment, the changes to the Object Info palette for DLVPs are for VW 2021, not for VW 2020. Sorry for the confusion. -
Oh and as to your other question, the behavior you describe sounds like a glitch. -
If the source file and the target file have the same user origin, then I believe you would want to set it to the opposite of the user origin. So if the user origin was offset from the internal origin by 50', 25' (XY), then the location of the DLVP should be -50',-25'. For VW 2020, the OIP for the DLVP has offset X, offset Y, and offset Z instead of X, Y, Z. Also the offset is not affected by the user origin, so to set it back to its original position, you would always set offset X, Y, Z to 0,0,0. -
I will try to answer your questions. I am assuming you are concerned with referenced DLVPs, so I my answer will be for referenced DLVPs. 1) What controls its position is the position of the original objects in the source file, any movement done to the DLVP (by dragging or by setting the x,y,z values on the OIP) and user origin changes. 2) I assume when you ask what would cause it to move, that you mean after you update the reference, it is in a different position. I think there are two possible causes. Obviously if the original objects in the source file were moved, it would move. Secondly if the user origin of DLVP's file was changed. For an example of the second case, I had a referenced DLVP and its center was at -100', 0 (xy). The user origin of the file was offset from the internal origin by 100', 0. I edited the user origin so it was offset from the internal origin by 120', 0. The DLVP did not move with respect to the page, but now its center was at -120',0. Then I updated the reference. The DLVP moved with respect to the page, so its center was back at -100', 0. 3) When you first create a referenced DLVP, the coordinates of its location should be the same as that of the original objects in the source file. For example, in the source file, I had some walls centered around -50', 0. The user origin of the file was offset from the internal origin by 50', 0, and the walls were at the center of the page. I created a referenced DLVP in another file, where the user origin of the file was offset from the internal origin by 100', 0. The center of the reference DLVP was at -50', 0, but it was 50' from the center of the page. -
Batch Convert Request...
Bruce Ferguson replied to shorter's question in Wishlist - Feature and Content Requests
An error dialog should not come up during Batch Convert. This is a bug. I have duplicated the problem. I will enter a bug report for this. -
Open Recent Menu Popouts
Bruce Ferguson replied to Haydenovative's question in Wishlist - Feature and Content Requests
I will enter a bug report about the file name being truncated.- 12 replies
- 2
- open recent
- menu popouts
(and 1 more)
Tagged with:
Boh, if you open a file in the recent files list, there is a File Info command in the File menu that will show information about the active file, including its location.- 12 replies
- 1
- open recent
- menu popouts
(and 1 more)
Tagged with:
That is not possible in VW2019.
VW2010 crashing on editing viewport annotations
Bruce Ferguson replied to Andrew Davies's topic in General Discussion
Andrew, Please send me a copy of your file. If possible send a copy from when it crashes wehn you edit the viewport annotations. Thanks, -
Shaun, You were the first person to report this oversight. We will try to fix this for an upcoming service pack. Thanks,
Michael, The eyedropper with the yellow star appears whenever you hold down the option and cmd keys and move the mouse. This indicates that when you click the mouse, you will be performing a Create Similar Object command. For example, if you option-cmd click when the mouse is over a rectangle, the rectangle tool will be active, and global settings will change to match the settings of the rectangle. So if the rectangle had a red fill, the global graphical attributes would be set to red fill. The eyedropper is used, because this functionality is very similar to using the eyedropper with the Pick Up Sets Defaults option on. The yellow star serves to distinguish this from the eyedropper functionality.
MSLD and Ride, If you have a reproducible crash, please send me your testfile and tell me what to do to get it to crash. Thanks, bruce@nemetschek.net
