MTRobin
Dimension Trailer Text
Hi Everyone,
Please see this Vectorscript I wrote below. I can see that it works in the OIP, but it won't update the dimension trailer. Can anyone advise on how to get this to work properly?
Thank you
Maxwell
PROCEDURE DimTypical;
VAR
Selection : HANDLE;
BEGIN
    Selection:= FSActLayer;
    SetObjectVariableString(Selection, 10, ' Typ.')
END;
Run(DimTypical);
Try adding a ResetBBox(Selection) or ResetObject(Selection).  You may also need to call Redraw or RedrawAll at the end of your code.
Yep. Works great. Thanks. I just realized that I can't select multiple dimensions and apply this script to them all. Is there a way to do this?
Thanks
Maxwell
Edited by MTRobin
You can do this using the single most powerful procedure in VS: ForEachObject. It also filters out other object so will only affect dimensions in this case.
PROCEDURE DoIt(h1 : HANDLE);
BEGIN
    SetObjectVariableString(h1, 10, ' Typ.');
    ResetObject(h1);
END;
BEGIN
    ForEachObject(DoIt, (T=DIMENSION) & Sel);
END;
Run(DimTypical);
It's possible you have picked up an invisible character by copying from the browser. Try deleting the last line and everything below it then retyping it manually. Or copy the script to a text editor and turn on invisible characters to see if you can spot something.
So I just noticed that this script doesn't work when I am editing the annotations of a viewport. Any thoughts?
Thanks
Maxwell
It looks like you forgot to add your DOIT procedure call before the criteria part.
Raymond
Edited by MullinRJ
