Kevin Allen
Model of a hospital bed with gear
I know I can go to 3D Warehouse, but I'm always suspicious. Anyone have a 3D model of a hospital bed, ideally with some medical gear as well?
There is a library in Service Select with some medical supplies and a hospital bed and some other equipment.  Not sure if this is what you are looking for but I thought I would share.  It is in Objects - Building Equip_Appliances>_Accessories  and Equipment Medical.
@Kevin Allen
Here is a hospital bed from Su. I cleaned it up, size looks fine, all faces correct, lightweight and when you import it make sure to tick create renderworks textures for all materials so you can then swap out the materials as required. Will create a level0 class so will need renaming, Layer name should be hospital bed.
Imports fine into VW but can't send you that one I have an edu version. Its
hospital bed.skp
