bjoerka 17 Posted April 12, 2019 we recently started to use the AR feature for client presentations. works very good in accordance to the tracking, layer classes stuff. good job. some things are strange. textures that are seamless sometimes show small gaps in the model and the surface starts flickering geometry (imported obj file) is rendered in the nomad 3d view without erros, but in the AR mode many faces are destructed. any hints what is going wrong here or how i can get rid of this? screenshot of nomad 3d model grid lines on the left of the roof bottom view of the roof @100% scaling car model in AR view. (original model format was obj) vw rendering Quote Share this post Link to post
0 Alex Nicol 36 Posted April 12, 2019 Hello, Do you mind sharing the file so we can take a look? You can either direct message me or share it here. Thanks! Alex 1 Quote Share this post Link to post
0 bjoerka 17 Posted April 12, 2019 thanks. i dropped you a message. Quote Share this post Link to post
0 Pat Stanford 1,625 Posted April 12, 2019 I have seen this before when you have two (or more) surfaces at exactly the same location. When the render engine runs in some places one surface is the one evaluated to show and at the next point over it could be the other surface that shows. If you can separate the surface by even a little bit (0.1 mm), then the surface conflict can be resolved. Not sure if this is the issue in your case, but worth a look. Quote Share this post Link to post
0 bjoerka 17 Posted April 12, 2019 (edited) yes. that is what i first thought on this issue. the original model came from rhino and was rebuild from scratch in vewctorworks but the roof is only one extrude and nothing else and the car has been rendered several times in rhino maya and c4d with v-ray and octane. and there it always looks perfect. Edited April 12, 2019 by bjoerka Quote Share this post Link to post
0 Alex Nicol 36 Posted April 19, 2019 We can reproduce this issue and will update here when we find a solution. It probably has to due with the imported OBJ mesh not being loaded properly by our app. Quote Share this post Link to post
0 bjoerka 17 Posted April 23, 2019 might that also be responsible for the gaps that occur in the texture tilings? Quote Share this post Link to post
vw rendering
