Marconi
Vectorworks 2019 "not optimized"
Just recieved this notification on my macbook pro when opening VW2019 this evening. I added my current VW specs in the screenshot as well
First time I'm ever seen this when opening VW. I've noticed some performance issues since installing SP3, but chalked it up to having too many other programs running. Now that I'm seeing this notification, I'm wondering if there is more to it.  Any one else having this issue?
5 answers to this question
This is just an overly sensitive alert in Mojave. It's been chiming in on some other of my major apps as well. It has to do with the OpenGL engine we use, there is a discussion on it here if you're interested in the details:
Thank you @Jim Wilson,
For what it's worth, I ran the first aid utility on my hard drive and noticed immediate performance improvements. Haven't seen that notification since. Thanks again.
Since upgrading iMac to Mojave (10.14.4) I get this message when launching Vectorworks 2019, SP3 ("Vectorworks 2019.app" not optimized for your Mac).  That is the message for non-64 bit apps that will not run on future versions of MacOS, likely the next version 10.15 out in the Fall.  Vectorworks is advertised as 64 bit, so what's up and will it stop work in  MacOS 10.15 (Death Valley?).
Just received the same message for the first time and I've been using VW2019 64bit for several months now with Mojave 10.14.4 installed. I'm assuming this error message can just be ignored since VW2019 and previous versions were already 64bit architecture. I'll attempt to run the first aid utility to see if that resolves the issue.
We're running on iMacs w/Retina 5k, 24GB of system memory and 2GB graphics memory.
