  • 1
erminio
Placing models with CameraMatch in distorted photos
Posted (edited)
Hi all,
I'm using CM occasionally since Vectorworks 2010 for architecture purpose
Now I'm asked to place large models in big areas far from me
So customers usually take pictures made by smartphones  with bad quality and big distortion
These areas  have no certain references and I've often to create panoramas merging pictures, adding even more distortion
Sometimes I also have to use Street Views snapshots
Is it possible to correct these kind of distortion?
Fortunately a big precision is not requested
Having a reasonable margin, I've tried the following trick but unsuccessfully
First I place the Ref Point, then the vert. lines and after the left and right lines, as better as possible
Try to see if the calculated horizontal line matches the picture one
I trace a new reference line where I think the horizontal line has to be and put the two vanishing points on it, moving green and red lines
Then I slide the vanishing points right and left  on the HL to match the perspective
The problem is that at a certain point green and red lines  misalign with the correspondent ref point. axes and the preview box goes out of perspective, getting me crazy
This has nothing to do with the picture distortion
What's wrong about that?
Does the error refers to blu vertical lines alignment?
PS: the picture is just an example of street view photo
Prove Camera Match 2.vwx
Edited by erminio
Updated example
3 answers to this question
Hi @erminio,
Lens barrel distortion can be corrected in image editors. There's an inexpensive application called PTLens designed just for this and has a huge database of camera and lenses with correction information. If you open an image taken by a camera and lens from its database, it will auto-correct it for you. I haven't used it in a few years, but it worked wonderfully when I did. It was well worth the price for me (I think it was 25 USD).
As for matching images that have been stitched together:  All bets are off.  The problem with this is that each image has its own set of vanishing points. Maybe you can get something close enough through trial and error, but I make no promises.
The preview object's perspective strays from the control lines when the vanishing points are positioned in an impossible (unrealistic) configuration. The pure math behind it all cannot calculate the view because the object could never be viewed with the three vanishing points in those locations. Usually it's the most parallel pair of control lines causing this problem. In your case, this would be the blue (vertical) control lines. Moving the top end of them slightly to the left or right might help correct the issue. Keep in mind: The closer to parallel a pair of control lines are, the bigger the change when changing the angle of them.
On 3/29/2019 at 8:26 PM, Matt Panzer said:
Hi @erminio,
Thank you Matt for your kind answer
As you say, I've seen CM cannot do magics on irrealistic images, so I gave it up
What I've done, to solve that, is placing a flat transparent image in Vectorworks, orienting the model as better as possible on that, then adjust in Photoshop
Not so easy and fast as CM, but works
You're welcome!
Yes. Not fun. That sounds like what I used to do before developing Camera Match. 😉
Good to hear you were able to get something you can use.
