Ride
Dimension precision doesn't update upon change
Using VW2019 Architect.  If I change the precision of my dimensions say from .1mm to .01mm, existing dimensions don't update.  New dimensions take on the set precision.
Is this expected behaviour?  I would expect any change to the dimension units, or precision, would update automatically.
UPDATE:  Things do update automatically IF I change to different units, then change back.  (i.e.:  if I change to inches, then back to mm with any precision, the dimensions all update as expected)
Edited by Ride
2 answers to this question
In my opinion, since each dimension can have its precision set individually in the OIP, this is the designed and correct behavior.
If I have manually set the precision for some dimensions and not for others and then I choose to change the setting for the document, I would not want the new document setting to necessarily override my manual settings. Think site plan versus detail.
You can either use your change the units (though I bet it only works if you change to fractional fee & inches) or select all the dimensions and change the setting in the OIP.
Thanks for the reply.  I'll carry on then, and select all and update when necessary.
