2d circle tool crashing VW2019
giannidowns
Hello all, My version of VW2019 is crashing nearly everytime I use the 2D circle tool. I've created a workaround by using the oval tool, but I rely on that circle tool a lot. Any fix to this that I can do on my end?
VW 2019 SP2 (build 463397) 64 bit
VW user for 18 years
MacBook Pro (retina, 15inch, mid2015)
macOS Mojave, vs 10.14.1
2.2 GHz Intel Core i7
16gb 1600 MHz ddr3
Intel Iris Pro 1536 MB
6 answers to this question
I'm running into this same issue—I've drawn several "spirals" using the poly line tool, used them to make closed 2D polygons, then extruded those into 3D shapes. Ever since then, drawing a circle gives me the spinning beach ball. It seems like I can draw anything else with no problem—straight lines, rectangles, more spirals, whatever. It's just circles that are causing everything to stop.
Both my OS and Vectorworks say they are up to date:
MacBook Pro OS Mojave 10.14.3
Vectorworks SP2 (build 463397) 64 bit
Any ideas to resolve that issue?
