Patrick West 3 Posted November 7, 2018 New problem for Vectorworks 2019 with Mojave. viewports with any rendtrworks basic options will not render. It will start to render and go through a quick preview, then it will be blank white. Please help. Quote Share this post Link to post
0 Seth Thomas 12 Posted November 7, 2018 (edited) Did you migrate your settings? Check your default compression setting. I just went through this and figured out that if it is set to JPG the rendering turns white, but PNG works. I had a discussion about it here: Edited November 7, 2018 by Seth Thomas 2 Quote Share this post Link to post
0 Patrick West 3 Posted November 7, 2018 @Seth Thomas Thank you! that worked. Changed compression to PNG. Quote Share this post Link to post
0 Seth Thomas 12 Posted November 7, 2018 5 minutes ago, Patrick West said: @Seth Thomas Thank you! that worked. Changed compression to PNG. You're welcome. Quote Share this post Link to post
0 MSLD 17 Posted December 16, 2018 Having same issue. As soon as viewport finishes rendering, it turns white. I took your suggestion and changed compression to PNG, and it works. Will this be fixed in SP3 or 4 or 5? Quote Share this post Link to post
Please help.
