bc Posted April 26, 2018 Share Posted April 26, 2018 (edited) I have received a VW file from another office and have been modeling the building in it. That office is still very 2D. They have a bunch of saved views that I want to use but there is the little annoyance that none of their Saved Views seem to have Unified View enabled. I thought this was a VW preference or setting that was universally independent but I guess I was wrong. I want it so that in every saved view Unified View is enabled. Can I edit these views in any way that is convenient (such as via the Org Palette)? I know I can enact a saved view, enable Unified View and then resave with same name and hence override. Just wondering if there was an easier way. edit: I also have Restore Unified View ticked in the SV edit dialog. Thanks Bradley Edited April 26, 2018 by bc added point Quote Link to comment
Andy Broomell Posted April 26, 2018 Share Posted April 26, 2018 Can you select them all in the Saved View tab of the Navigation Palette (or Organization Palette), right click, choose Edit, then simply uncheck "Restore Unified View"? I'm pretty sure this checkbox actually saves whether Unified View was on or off, and its settings(?), despite erroneously sounding like it "restores" Unified View. It should really be labeled "Restore Unified View Status." So if you uncheck that box for all the Saved Views, you should be able to just turn on Unified View once and it should stay on without being affected by the Saved Views. Quote Link to comment
bc Posted April 27, 2018 Author Share Posted April 27, 2018 THANKS ANDY, THAT DID IT. BRADLEY Quote Link to comment
RickR Posted May 2, 2018 Share Posted May 2, 2018 I've found the simple way to edit Saved Views is to redefine them. Activate the View Change what you want Right click on the view name in Navigation and select Redefine Make any further changes in the dialog - which is basically what to save or not save. Quote Link to comment
bc Posted May 2, 2018 Author Share Posted May 2, 2018 Useful tip RickR, thanks for that. Quote Link to comment
