bruce choi Posted August 21, 2004 Share Posted August 21, 2004 This is more about the VW11 capability. Is there a way to extend multiful lines at once? Thank you!!!! Quote Link to comment
JHEarcht Posted August 23, 2004 Share Posted August 23, 2004 Bruce, In VW11 you can use the "Connect/Combine" tool to extend multiple lines to a boundary line. With "Single Object Connect" function, select the lines to be extended and hold down the ALT/Option key as you click on the boundary line. Refer to page 12-9 in the VW User's Guide for more info. This is a useful feature that I have wished for many times. JE Quote Link to comment
cairo9 Posted August 23, 2004 Share Posted August 23, 2004 The best thing about this feature is that if you want multiple lines to extend to one line with this command ---if there are some lines which needs to be trimed can also be selected. I mean if 5 lines needs to be extended and 5 lines needed to be trimed about the same line simuntaniously , the same procedure can be done as told by JE Quote Link to comment
tgm Posted August 24, 2004 Share Posted August 24, 2004 Interesting as I was just about to post a note on this topic as tonite I could not get the Connect/Combine tool to work. No where on 12-9 does it say anything about holding down Alt-L in order to make this tool work. If you follow the manual instructions and the command line , using Single Object Connect Mode, you pick the end of the object to extend and then click on the boundry. This does not work at all. Has anyone else had this problem?? Tom in PA Quote Link to comment
gasjar Posted September 2, 2004 Share Posted September 2, 2004 Yes, I just ended up at this chat for the same reason. The DVD Learning Series says nothing about Alt/ Option either. Useful tip! Quote Link to comment
tgm Posted September 2, 2004 Share Posted September 2, 2004 Interesting that no one from VW has chimed in on what is definitely a 'bug' and needs resolution. Tom in PA Quote Link to comment
JHEarcht Posted September 2, 2004 Share Posted September 2, 2004 In the middle of page 12-9, under Single Object Connect, the User Guide says: "By pressing ALT (Windows) or Option (Macintosh), this mode allows multiple objects to be connected to a boundary object" JE Quote Link to comment
jmartinarch Posted September 7, 2004 Share Posted September 7, 2004 Alt-L is to invoke the command, but that is only after selecting the multiple objects, then hold Alt as you click one of the objects to extend to the boundary. This is a great help to me. Thanks JHE, and Cairo. Quote Link to comment
