bruce choi
    14
Reputation
0 Neutral
Personal Information
  • Occupation
    designer
  • Location
    emeryville
  1. Hi, Does anyone know where I can download concrete hatch pattern. I'd like to have aggregates in the pattern. I've tried 'VECTORDEPOT' already, they only have hatch pattern for old version. I have vector works 11.5 in Macintosh base. Your tip will be greatly appreciated. Thank you.
  2. Hi, Does anyone know how to set mouse scroll button to zoom in&out. It only works as pan(up & down) which is not very functional. I have OS10.3.9 and Vectorworks 11.5. Your help will be greatly appreciated. Thank you. Bruce
  3. I am using VectorWorks 11.5 in Mac os 10.3.8. I am wondering if there is a lock function in togling between layers. Everytime I ckick an object within a same scaled layer, the clicked layer becomes active. This could be a convinience, but there are some cases that I don't want this function. I usually do my notes in note layer with bunch of referenced drawings. When I click any of the referenced layers by accident, the referenced layer becomes active. Afeter that all my note are mixed up in different layers. I hope there is a lock function in togling, so that I know I stay in the 'Note' layer as long as I'm doing notes. Your answer will be greatly appretiated. Thank you.
  4. Thank you for all the answers. Basically, I was curious about the 'thumb nail' view which George Hannigan mentioned. So that I have a good sense what the drawings in the file looks like before opening it. Thank you.
  5. Does anyone know how to enable the preview? When I select a VectorWoks file, it say preview and shows vwctorWorks 11 logo. I'd like to see a 'preview' as drawing in the file. Your answer will be greatly appreciated. Thank you. Bruce
  6. One of the weak tools of vector works, compare to AutoCAD, is the pasting capability. Often times, I want to paste a certain point of an objects to a certain reference pont. It is just a waste of time doing 'paste' and 'place' it later. Does anybody know Vectorworks has such a function? Thank you.
  7. One of the weak tools of vector works, compare to AutoCAD, is the pasting capability. Often times, I want to paste a certain point of an objects to a certain reference pont rather than placing it later. It is just a waste of time doing 'paste' and place it later. If anybody know Vectorworks has such a function? Thank you.
  8. Thank you Patrick. I didn't use view port. I just have bunch of drawings 'grouped'. I laid them in to different scaled layers. We have HP 1055cm plotter. I have Power Mac G-4. 1.25G OS 10.3.4 VW 11.1 Thank you for your help.
  9. I see a line across in a print, but I don't see a line in the file. I want to delete the line. This is 2nd time happening. Any tips? Thank you.
  10. I'm wondering if this is a bug of the VW11. I use curved lines for my details, and I have differenr scaled drawings on a sheet. When i change the layer to another scale, all the arrow head on my leader are gone. Your answer will be greatly appreciated. Thank you.
  11. This is more about the VW11 capability. Is there a way to extend multiful lines at once? Thank you!!!!
  12. I'm wondering if there is a toogle option availale in VW11. VW8.5 had the option. VW goes back to previous tool when the same short key is punched. It's a quiet convienient option. Please, lemt me know if there is a setting to have that option 'ON' Thank you.
  13. I know that OSX adjust memory by itself. I'm still wondering if there's a way to allocate more memory to vector works. I have OS 10.3.4 and vectorworks 11. I have 768M of RAM, but it doesn't work flawlessly woth vectorworks-Vectorworks freezes for a couple of seconds sometimes. I wish I can give more memory to Vetorworks
