RonaldHH
Design Viewport not showing in Sheet Viewport
Hello All,
Here is my issue...I set up section viewports to be applied to a design layer for annotation. From there, I created another viewport for the drawing to be placed on a sheet. The viewport on the sheet does not show the design viewport in a handful of instances, but in some, it works fine. I have checked visibilities from classes, layers, ect.
I have tried using the eyedropper tool to copy attributes from the viewports that are showing, to the ones that are not, but no luck. I am at a loss! Any ideas?
Share on other sites
4 answers to this question
@RonaldHHHi, Are all your design layers the same scale?
Normally I would create a section viewport and place it on a sheet layer then annotate in the annotations layer of that viewport.
If sometimes i want to bring the viewport back to a design layer i will convert to lines and copy paste to design layer and scale it up by 100 (Metric and design layer set to 1:100)
HTH
Thanks Alan,
yes, all the layers are at the same scale. I set up the drawing up this way so that I could put all sections on the same layer, and be able to add linework detail easily. I can then transfer detail from section to the other without having to jump between sheet viewports. It saved me loads of time, except for this last hangup!
Attached are a couple screenshots to show the issue...
UPDATE: I found a workaround, which is to copy the viewports on the design layer, and covert them to goups. I will just have to update them manually, so it is a bit of a pain. Almost done with CD's, so might sort this out on the next project...
Sheet viewport enforce "unified view" they must all be in the same view orientation as well as scale.
If you have a 2D design layer viewport showing in a Section viewport you can't make a sheet viewport that shows that. My workaround is to stack up viewports on the sheet. Align them carefully and everything is fine.
