MHBrown
Data Stamp still broken in VW2017
Has anyone else noticed that the Data Stamp still doesn't work in the newest version, VW2017? Specifically, the file name does not update automatically nor will it update by "refreshing" in the info palette. The date updates using the info palette, but the file name will not change. The same workaround as we previous versions is required: delete the existing stamp and replace it with a new one every time you update your file. Is this just happening to me or is it still a bug for the bug list?
MHBrown
2 answers to this question
To force an update to the Data Stamp, I disable and re-enable the check mark for 'Show File Name' on the Data Stamp OIP.
In Vw2016, at least, that works to force it to update the file name. (I have never had to delete the existing Data Stamp & insert a new one like you describe).
Thanks, but that hasn't worked for me since VW2013. I have to delete and insert the new one. Perhaps it has something to do with my title block being a symbol, but I assume most users make their title block a symbol.
