michaelk
Simplify Polys
I'm writing a script that automates an action that I need to repeat approximately a gazillion times  in a drawing.
One of the steps is Modify > Drafting Aids > Simplify Polys… > Maximum Deviation 1"
Can't get DoMenuTextByName to call the Simplify Polys dialog, and I'm not seeing a real way to script it.
Any advice?
MK
That seems like it would work.
What am I misunderstanding about DoMenuTextByName? Or is there just a limitation to that function that doesn't go that deep into the chunks?
I don't think DoMenuTextByName actually works on anything in Chunks unless there is a specifically defined chunk.
Drafting Aids is not a defined chunk, so I don't think you can get to it.
Try creating a new menu with that command at the top level and see if you can get to it from there.
Thanks, Pat.  What an elegant idea.  Now that you've said it, it seems blindingly obvious.  But it would never have occurred to me :-)
I managed to do 1 gazillion operations with the script I had.  Next time I'm trying that!
mk
