RussU Posted May 13, 2017 Share Posted May 13, 2017 Hi everyone. Stil have a problem, which was sorted, then came back in SP3 Draw a sheet layer viewport of something.. then do a rounded rectangle over it... Create detail viewport. grab the detail view and select edit crop. drag the handles around to tighten or loosen it, and change from proportional corners to symetrical corners... exit edit crop now look at the detail callout shape... it's all gone mental! Quote Link to comment
0 markdd Posted May 13, 2017 Share Posted May 13, 2017 I managed to make it go mental once. Thereafter it behaved perfectly. Odd! Can't manage to get the detail viewport on a sheet layer to create a label though despite checking the box. Works fine on a design layer..... Quote Link to comment
0 RussU Posted May 15, 2017 Author Share Posted May 15, 2017 On 13/05/2017 at 6:19 PM, markdd said: I managed to make it go mental once. Thereafter it behaved perfectly. Odd! Can't manage to get the detail viewport on a sheet layer to create a label though despite checking the box. Works fine on a design layer..... Have you double checked to make sure that the active class is visible in the viewport settings? I've had it before where anything you create on a class which is active, and nothing appears no matter how many times you click.... then you activate it in the VP visability and boom, suddendly all those invisible things appear. 1 Quote Link to comment
0 markdd Posted May 15, 2017 Share Posted May 15, 2017 Thanks @RussU completely correct! 1 Quote Link to comment
RussU
Hi everyone.
3 answers to this question
