Bruce Kieffer Posted January 18, 2004 Share Posted January 18, 2004 Here's an example to demonstrate my problem: Open a new drawing, set the scale to 1" = 1", and draw a 4" x 1" rectangle. Select the Fillet tool, set the fillet radius to 1/2", click on the "fillet and trim mode" setting, and try either clicking an edge of the rectangle which should fillet all corners, or drag across the corners to fillet them one at a time. Most often I can only fillet 2 corners, rarely 3 corners, and almost never will it do 4 corners. If I add .001" to the height of the rectangle, it will fillet all 4 corners. Does anyone else consider this an issue? Quote Link to comment
P Retondo Posted January 19, 2004 Share Posted January 19, 2004 What version of VW are you using? In the old days, with 32 bit precision, it could be a problem to set a fillet to exactly 1/2 the length of a side. Im my current system, double clicking on the 1" x 4" rectangle successfully fillets all corners. VW 10.5.1 Win2K Quote Link to comment
Bruce Kieffer Posted January 23, 2004 Author Share Posted January 23, 2004 VW 10.5.1 and Mac OS X 10.3.2. I'm been told to test with a higher 2D resolution. I' will report back when I have done that. Quote Link to comment
Bruce Kieffer Posted January 24, 2004 Author Share Posted January 24, 2004 I tested the higher 2D resolution and the results were inconclusive. Sometimes the fillet command rounds all 4 corners, sometimes not. Quote Link to comment
Guest Posted January 26, 2004 Share Posted January 26, 2004 Bruce, Please email this information to bugsubmit@nemetschek.net so the bugs can be entered and fixed. Quote Link to comment
rjtiedeman Posted January 27, 2004 Share Posted January 27, 2004 Bruce, I have had the same issue with MiniCad, Vector works and other Cad software. The work around I have found to get the rounding to work to the max is as follows: 1. make the 4" x 1" rectangle. 2. convert it to a polygon (tools pull down menu) 3. use the 2d reshape tool to change the vertex to a circular fillet. This always works for me. If you need further help. Look at page 305-Reshaping Objects (Vectorworks PDF.) Robert John Tiedemann Quote Link to comment
