Jose E. Calderon Posted February 25, 2017 Share Posted February 25, 2017 (edited) I have no idea what I am doing wrong. I created the Site model follow by a polygon and a site modifier pad. I se the pad height but the contour lines are not modified at all. See That I have a small polygon and a modified pad around the pad. Here is a link to the file https://www.dropbox.com/s/es3twjlnpsus5ct/HaciendaLosPozos.vwx?dl=0 I also notice that the contour lines are all solid. This is contrary to the documentation showing the original to be dashed lines. Edited February 25, 2017 by Jose E. Calderon Add link to file Quote Link to comment
AlanW Posted February 25, 2017 Share Posted February 25, 2017 @Jose E. CalderonHi, there appears to be 1 model on top of the contours so I pulled one away the model and recreated the site using the remaining contours and seemed to work. HTH HaciendaLosPozos.vwx 1 Quote Link to comment
CipesDesign Posted February 25, 2017 Share Posted February 25, 2017 I also noticed that in the original screen shots "Existing Only" was checked in 3d Display. Try changing that to Proposed and then Update the Site Model. 1 Quote Link to comment
