Josh NZ Posted February 19, 2017 Share Posted February 19, 2017 (edited) This is probably a rookie question. I have my snap grid set to 10mm, however when I'm dragging copies of objects I'm still getting increments of 5mm on occasions. Is there another setting somewhere? Edited February 19, 2017 by Josh NZ Quote Link to comment
bcd Posted February 19, 2017 Share Posted February 19, 2017 You're snapping to everything. The 10x10 grid, endpoints, Angles, extensions, fractions of a line, edges etc. What you're seeing as a 5mm snap is probably a 5mm dimension precision. Take a look at File>Document Settings>Units and see if the rounding base is set to 5. Set it to 1 and you'll likely see those 25's become 23 or 24 etc. Quote Link to comment
Josh NZ Posted February 19, 2017 Author Share Posted February 19, 2017 Hi BCD, have checked and rounding base is already less than 5. The x and y positions in the OIP also have values not equal to units of 10mm. I would have expected that with the snap to grid set to 10mm that providing you weren't using a command such as move or distribute, that they would be moved in increments of 10mm. Maybe I'm not understanding the feature correctly. Quote Link to comment
bcd Posted February 19, 2017 Share Posted February 19, 2017 (edited) The 10x10 grid doesn't force itself on objects, rather it provides an additional set of snapable loci across the drawing area. So a 10mm line snapped to the grid will happily offer it's midpoint as a snap point if midpoint snaps are enabled. Edited February 19, 2017 by bcd Quote Link to comment
bcd Posted February 19, 2017 Share Posted February 19, 2017 Oh - looking back at your drawing. How wide is your wall? Quote Link to comment
Jeremy Best Posted February 24, 2017 Share Posted February 24, 2017 This is normal behaviour. There are multiple possible explanations so I'll just list one I think most likely: If you (for sake of examination) make the snap grid 10mm, the reference grid the same, then zoom in and deal with objects only 5 times longer/wider than the snap grid, it becomes easy to witness the snapping occurrences and deduce the logic behind them. For example, make a 50mm square with its top left corner on a grid point, grab its edge centre, then slowly drag it rightward with your cursor slightly above the square's edge to avoid object-related snaps. The first move will be 5mm where it first locks to the snap grid. Subsequent movements will add 10mm. 5... 15... 25... When you let go, the square's top left corner will be an increment of 5 away from where it began. 'Where on an object you grab,' is just one of multiple explanations of how your wall spacings may have reached 5mm increments. Quote Link to comment
