Gabriel Chan
Applying gobo texture to Lighting fixtures crashes the Vectorworks 2017
Hi all,
Followed the Vectorworks video online https://www.youtube.com/watch?v=4znYJ8qCxcg&index=16&list=PLiLCoe7DU1HZZEmPKJoBCLBGNPnMhZfTp in an attempt to apply gobo textures into my drawing.
In the "Edit Lighting Device" dialogue, I click the "Get Resource" button, select the gobo texture I imported, clicked OK once to exit the "Import External Resource" pop up. On the next click on the OK button to exit the "Edit Lighting Device" dialogue, Vectorworks immediately crashes.
I am currently on Vectorworks 2017, with a mid 2012 Retina MacBook Pro.
Any ideas to what might be causing this?
Gabriel Chan
Vectorworks Spotlight user since version 2011.
VWX Crash report copy.xml
8 answers to this question
Backup and reset your Vectorworks preferences as described here:
Then, reboot your machine and try doing that again. Let me know the results.
Hi JimW,
Resetting Vectorworks Preferences, step number
2) Throw away the “ net.nemetschek.vectorworks20XX.plist” file from 'HD > Library > Preferences'
I find 2 files:
net.nemetschek.vectorworks.plist
net.vectorworks.vectorworks.2017.plist
None of which tally with the file string name. Do I delete both in this case?
Thanks for the quick response by the way.
Gabriel
Contact support directly in that case, they may also ask for this from your machine:
Did a full uninstall of the software and a clean install. This time round without using migration assistant to port over my workspace settings from my 2011 version.
Seems to have resolved the problems when applying the gobo to the lighting device.
I suspect it might have been some remnants of my VW2011 workspace preferences causing the problem.
Gabriel
Same here: gobo crashed VW instantly & reliably.
Didn't use Migration Assistant, using unedited Spotlight Workspace
Edited by bcd
