- 0
"You have tried to create an empty solid object."?
Asked by
guten_morgen
Asked by
guten_morgen
7150 Riverwood Drive, Columbia, Maryland 21046, USA | Contact Us: 410-290-5114
© 2018 Vectorworks, Inc. All Rights Reserved. Vectorworks, Inc. is part of the Nemetschek Group.
Hi,
I am trying to execute a simple solid subtraction and am receiving the error message, "You have tried to create an empty solid object." I'm not sure why this is happening. The solids are intersecting one another, the object I'm trying to subtract from is highlighted in red when I go to execute the subtraction, and I am only selecting the two objects.
Both objects are extruded polygons (the end vertices are connected). One was created using the simple point-by-point method, the other was created using the inner boundary mode (paint bucket), as I was created a 3D shape to fit perfectly inside a gothic style door frame. Both objects are on the same layer. Both objects are of the same class.
I gave as much information as I could think of because I don't know what I'm doing wrong and maybe some of this will assist in evaluating the situation.
I don't mind attaching the file if anyone needs to see it.
Thanks in advance!
