Force objects to move at grid intervals
Bruce Kieffer
2 answers to this question
Hold down the Command key while you drag and you should move in snap grid dimensions. If the object was originally on the grid it should stay on.
Similarly, if you hold down the Shift and Command keys and use the arrow keys the object will Nudge by the snap grid.
I recommend that you set a much larger grid Maybe 6 or 12 inches in a test file and play with it there so you can easily see the results.
