Christian Fekete Posted October 13, 2016 Share Posted October 13, 2016 Can someone tell me how to render the door panels of the example below as transparent? Thank you CF door with glass panels.vwx Quote Link to comment
michaelk Posted October 13, 2016 Share Posted October 13, 2016 The door in your file seems to be corrupted. Did it come from an earlier version of VW? If you select the door, then OIP > Settings > Classes and then set the Interior and Exterior Panel classes to a class that has a clear glass texture (like Glazing-Clear) then the panel will be /should be/ clear. For some reason, if you blow your door apart, the extrude that makes up the panel part of the door has it's texture set to None when it should be Class Texture. Try creating a new door. Should work. hth mk Quote Link to comment
AlanW Posted October 14, 2016 Share Posted October 14, 2016 Hi, You need to set your door leaf type to glass not solid. see attached. This refers to the door panel section not the overall door leaf. Probable wrong terminology. HTH Quote Link to comment
Christian Fekete Posted October 21, 2016 Author Share Posted October 21, 2016 That's IT Thank you Alan for your time, Best CF 1 Quote Link to comment
