Skem Posted September 4, 2003 Share Posted September 4, 2003 I've searched high and low....how do you put an opening in a wall??? Thanks for the help. Susie Quote Link to comment
zero Posted September 4, 2003 Share Posted September 4, 2003 vw10 - insert a door object, change its type to "cased opening" Quote Link to comment
Skem Posted September 4, 2003 Author Share Posted September 4, 2003 Hey Zero...I have been through the Object Info Palette, several times over....where do I find the "cased opening" label? Thanks much for your info. Susie VW10 Quote Link to comment
Chris T Posted September 4, 2003 Share Posted September 4, 2003 LOOK ON THE "OBJECTS" PALETTE. SELECT "DOOR" Quote Link to comment
CipesDesign Posted September 4, 2003 Share Posted September 4, 2003 Susie, After you insert a door into a wall, go to the Object Info palette and click on the button (tab) called "GENERAL SETTINGS", this will allow you to change size & type of door. Peter Quote Link to comment
