Chris T
66 -
Never
Everything posted by Chris T
When I add a new sheet/'s to a VWA10.5 file from the setup menu all of my classes revert to the default attributes. It undoes all my changes to the classes. A lot of work to redo them. Is there a way to set my own default attributes to classes?
you multiply the horizontal flat area by percentage factor of the roof pitch. ie. a bldg 8'x12'=96sqft with a 7:12 pitch (96sqft x 1.158)=111.168sqft roof area. see "Builders vest pocket Ref. Book" for factors
THESE BUG WHERE FIXED IN VWA 10.5 1. SOMETIME WHEN VWA IS OPENED THE SIZE IS VERY SMALL. 2. ALSO AT START UP PEN THICKNESS CHANGES TO pts. I USE mm AND HAVE TO CHANGE THIS EVERY TIME I START VWA. 3. DOORS AND WINDOWS A. GAPS IN THE WALL NEXT TO A DOOR SYMBOL B. ON ONE FILE ALL MY DOORS DISAPPEARED
I have had this problem in 2D mode. The work around is, you have to goto LAyers dialog box select all layers with the same scale and re-select the scale. This will work most of the time, but there is a bug because sometimes it does that any.
IT WOULD BE NICE TO FIX THESE BUGS IN THE UP COMING VWA10.5.1 1. PIO. "WINDOWS" CASEMENT WINDOW HAVE NO SWING AND LOOKS LIKE A FIXED WINDOW. 2. LINE THICKNESS DEFAULT OR CHANGES TO POINTS OR mil. I HAVE TO CHANGE IT TO mm ALL THE TIME.
I have been committed to using VWA 10.5 and have been using minicad since V4. We all love new futures BUT WOULD RATHER NOT HAVE THEM IF IT IS GOING TO CAUSE PROBLEMS FOR THE EXISTING TOOLS. NOW. VWA 10.5 SIMMS TO BE SLOWING PRODUCTION? I'M NOT SURE WHAT IT IS BUT I HAVE NOTICED A FEW LITTLE BUGS, WHICH I HAVE SUBMITTED BEFORE. I WAS HOPING THERE WOULD HAVE BEEN FIX IN VWA 10.5. IN ADDITION TO THE TWO POSTED THIS WEEK, HERE ARE A FEW MORE. I HOPE THESE CAN BE FIXED BEFORE A MAJOR UPGRADE. 1. THE TEXT IN SOME DIALOG BOXES LOOK SMALL. 2. THE CHANGES TO 6PTS AT START UP. 3. PEN THICKNESS IN ATTRIBUTES CHANGES THE UNITS FROM mm TO pts OR mils posted 09-28-2003 05:23 PM -------------------------------------------------------------------------------- 1. The snap and cursor cues are very inconsistent, when two or more layers with the same scale and view. "sometimes" this can be fix by going to the layer edit box and selecting the imperial 1/4" even if the paper scale is 1:48.00 2. I have a large site w/ 6 bldgs. So I Workgroup Ref. each building to my site file. Then layer linked bldgs. To Site Levels (1-7) Then Layer linked Site levels to site sheets i.e. (site layout, grading & landscape. The bldgs shows up twice on these sheets. One in place the other as a ghost, which cannot be selected in the middle of the sheets. Why? Crash while move a grouped layer links on a perspective sheet
Thanks Katie, Sound simple enough.
I want to upgrade from VWA10.1.2 to VWA10.5 At the office is a network running WinXP pro. I have asked the IT guy to upgrade VWA he "say" that on a notice board it said VWA has problems with the network. He does not want to upgrade all the workstations and goes not want to just upgrade my station. He wants to wait till VWA10.5 is upgraded.?? He said that upgrading just one computer causes problems with the licenses. Whoever there are 3 Mac?s connected to the network, which has already upgraded to VWA 10.5 and has no problems. Could you give me a word on any know problems as I have described. Thank you
Thanks for the reply. I will try it and get back to you.
How do I open Minicad 4 Files? We have a few files which we need to open / convernt to VWA 10.5 I still have my copy of minicad 7, VW8 & VWA9. The file we have are Mac files. Can we load Minicad 7 or VW8 on Windows 2000 or XP? or on Mac OS X ?
HI KEVIN, I HAVE HAD THE SAME PROBLEMS WITH THE ANIMATION AS YOU ARE HAVING. I WAS ABLE TO WORK AROUND THE ORBIT ANIMATION BY KEEPING THE ROTATION TO BELOW 60 OR 90. TEST IT YOU KNOW THAT YOU HAVE TO WAIT THE FIVE HOURS TILL YOU FIND OUT IF IT WORKS. VWA 10.5 IS MORE STABLE BUT I DO NOT WANT TO SPEAK TOO SOON. THE WALK THRU I'M STILL WORKING ON. ANY IDEA'S ANYONE?
LOOK ON THE "OBJECTS" PALETTE. SELECT "DOOR"
THANKS FOR THE REPLIES. THERE IS NO WAY TO CONTROL THE PILASTER OR COLUMN SIZE. CAN'T DO A COLUMN 8X20" I USE THE EXTRUSION TO DO THE COLUMNS AND ROOF. I MADE A 2D POLYGON SECTION OF THE WALL AND CURVED ROOF THEN PUT THE LAYER INTO A FRONT VIEW AND EXTRUDES THE SECTION TO THE LENGTH. LOOKS GREAT RENDERED BUT NOT IN PLAN. YOU CAN CREATE HOW YOU WOULD WANT IT TO LOOK IN 2D PLAN BY MAKING A SYMBOL WITH THE 3D EXTRUSION. IT WOULD BE NICE IF VWA CAN TAPER WALLS AND HAVE RECTANGLE COLUMNS
I HAVE A FEW QUESTIONS ON THE BEST WAY TO SHOW THE FOLLOWING: 1. CREATING A TAPERING WALL OR ONLY THE FRONT OF A COLUMN WITH THE BACK STRAIGHT. 2. CREATE A CURVED ROOF EAVE ANY HELP AND SUGGESTIONS ARE WELCOME
When I add a new floor to an existing file and then add the sheets. The class attributes which I customised changes to the default. Can this be fixed before the next upgrade to VWA. Thanks
I was using the double poly tool and reshape it. Now I use the roadway tool and it works great. -can change road width with no problems. -intersections(tee) corners works very well. - best of all it is in 3D and you can see the slopes. I started using it on a commercial project and sasve a lot of time.
Why is it that the gray layer's: 1. Text on the prints and shows a gray box for the text? Couldn't it just show the gray text or not show anything! 2. Dashed line are not dashed ?
I like the new wall join tools for the most part the . But the X jion should go back to the way it was in VWA9 because most of the time you have to move or change the wall. With the new way of doing things you have to delete the wall.
THIS IS A WISH LIST ITEM IT WOULD BE USEFUL WHEN DOING ENLARGE PLANS. I DO IT THE WAY ZERO SAID BUT BE CAREFUL IF YOU USE VW DOOR/ WINDOW SCHEDULES OR OTHERS. ON THE COPIED PLAN UNSELECT THE DATA TAB OF THE SYMBOLS. NOW WHEN YOU DOUBLE CLICK ON A LAYER LINK IT TAKES YOU TO THE REF. LAYER. I LIKE THAT BUT IT SHOULD HAVE A DONE BOTTON TO GO BACK TO THE LAYER YOU HAVE THE LINK ON.
BEFORE I GO SET UP A TEMPLATE FILE OF EVERY SHEET. WHICH IS NOT WHAT WE A TALKING ABOUT. WE ARE TALKING ABOUT LAYERS & CLASSES NOT SHEETS. DO YOU AGREE WITH ME THAT THIS "AEC" FILE SHOULD BE THERE? IT WAS IN VWA 8 AND WAS TAKEN OUT IN VWA9 & 10 WOULDN'T IT BE EASIER TO PUT BACK THE "AEC LAYERS & CLASSES.sta" FILE INTO THE STANDARDS FOLDER, ALONG WITH THE AIA STANDARDS. IT HAS ALL THE AEC LAYERS & CLASSES. THE AEC FILE HAS TO BE IN THE STANDARDS FOLDER TO SHOW UP IN THE "SELECT STANDARD NAMING" DROP MENU WHEN CREATING A NEW LAYER OR CLASS. I COULD SEND YOU THE FILE.
"ARCHITECTS" WORK IN CAPS AND WRITE IN CAPS AND WE DO NOT SHOUT AT ANYONE, BUT BUILDERS. YES "ROBERT" YOU DO RESPOND TO POST BUT DON'T BE JEALOUS, KATIE IS A LADY, WHERE I COME FROM LADIES LIKE COMPLIMENTS 3. Exactly what version of VW10 are you using? There are some wall regeneration issues that have been fixed in upgrades. And are you using the Connected Walls mode? I AM USING VWA10.1 I USE THE SETUP TO START MY PROJECT ? (SETUP THE MODEL, LAYERS AND SHEETS) IT IS VERY USEFUL. NOW THAT THE FILE HAS ALL THE SHEETS, LAYERS AND CLASSES YOU NEED. NOW YOU WANT TO ADD A "NEW" CLASS OR LAYER. CAN YOU ADD A NEW CLASS OR LAYER NAMED "Mod-Floor-# OR Area-Main" FROM ?menu ORGANIZE > CLASS OR LAYER? "SELECT FROM STANDARD"? HOW DO YOU ADD THESE LAYERS OR CLASSES? I DID NOT UPDATE TO VWA10.1.2 BECAUSE I NEED TO FINISH A PROJECT AND DO NOT HAVE THE TIME TO CHECK IF IT WORKS RIGHT. I WAS TRYING TO SAY THAT SOME OF THE NEW FEATURES ARE GREAT, BUT SOME OF THE CHANGES ARE NOT BETTER THAN THE OLD WAY. FOR EXAMPLE THE WALL JOIN CROSS TOOL. WHERE THE NEW TOOL CUTS THE WALL SO IF YOU NEED TO MOVE THE WALL, YOU WOULD HAVE TO SELECT ALL THE WALLS.
I HAVE BEEN WORKING WITH MINCAD / VWA10 SINCE 1995 AND HAVE RECOMMENDED IT TO OVER 12 USERS WHO HAVE PURCHASED IT. SO I THINK I KNOW HOW TO INSERT A DOOR INTO A WALL. OK, SORRY KATIE BUT YOU ARE THE ONLY ONE I SEE WHO TRY TO HELP AND REGULARLY ANSWER TO THESE POST! "1. How do you make changes like add hatches." (TO Setup>Standard Naming.) AT THE Setup>Standard Naming. BOX THERE ARE A FEW PROBLEMS OR LIMITATIONS. A.- LINE THICKNESS UNITS ARE (Mils.) HOW CAN I CHANGE THE UNITS TO (mm)? B.- COLORS! USES A DIFFERENT COLOR PALETTE THAN THE ATTRIBUTES PALETTE. WHY? C.- THE ATTRIBUTES PALETTE AND ORGANIZE>CLASSES ALLOWS YOU TO MAKE CHANGES TO YOUR FILL AND PEN TO (NONE, SOLID, PATTERN, HATCHES, GRADIENT, IMAGE.) HOW CAN I NOT SET THE HATCHES TO CLASSES FROM THE "Setup>Standard Naming". 2. This File ?AEC Layers & Classes? doesn't come with VWA10 or VWA9. I had to bring it in from VWA8. Without it you cannot add layers like "Mod-Floor" or classes "Wall-Ext-Frame". FROM VWA9 OR 10 WITHOUT ?AEC Layers & Classes.sta? FILE, ADD A "NEW" CLASS OR LAYER. CAN YOU ADD A NEW CLASS OR LAYER NAMED "Mod-Floor-# OR Area-Main" FROM "SELECT FROM STANDARD"? THIS FILE IS IMPORTANT IF YOU WANT TO ADD A NEW AEC LAYER OR CLASS. THIS IS A STANDARDS FILE THAT HAS BEEN FORGOTTEN. "the worst thing about the new wall join is the cross join, it breaks the walls at the joints?" THE PROBLEM WITH THIS IS CHANGES. IF I HAVE TO MOVE THE WALL, IT'S ALL BROKEN. WHY WAS THIS CHANGED FROM VWA9 AND BEYOND? "IF IT'S NOT BROKEN DON'T FIX IT" I CAN'T BELIEVE THAT THIS IS AN IMPROVEMENT. "Also when I move a wall the ajoining walls loses the door symbols" This should only happen if the doors are not IN the wall. I DON'T SEE WHY THIS WOULD HAPPEN? IF A SYMBOL IS NOT IN A WALL, WHY SHOULD MOVING THE WALL AFFECT THE SYMBOL? NO THIS HAPPENS WHEN THE WALLS A JOINED TOGETHER, WHICH THEY SHOULD BE. I HAVE TO USE THE REMOVE WALL BREAKS TOOL, MOVE THE WALL THEN JOIN THE WALLS BACK. I HAVE AN IDEA FOR VWA10.5 OR 11!! STOP GIVE US NEW FEATURES, FIX AND IMPROVE EXISTING TOOLS & MENUS.
