jmartinarch Posted September 28, 2016 Share Posted September 28, 2016 I need to show a thickened or offset wall. See image left side, hollow rectangle that matches the small wall sections in the middle and the thickened wall section on the right. And what do wall offsets really describe? Changes to top & or bottom of wall segments? Or wall thickness like I am trying to demonstrate? Or just any change to the plane of the wall? So, what sort of monkeying around can I anticipate in order to yield the results I want? The typical walls are 3.5" and the thicker wall segments (casi columns) are 6". Quote Link to comment
jmartinarch Posted September 28, 2016 Author Share Posted September 28, 2016 Solved, I think. I placed the wider section of wall in the footprint of the hollow rectangle and then placed a rectangle over the lower left corner (next to door jamb) that I wanted to remove and used clip surface and it worked! Quote Link to comment
jmartinarch Posted September 30, 2016 Author Share Posted September 30, 2016 Well it didn't really work. It left a little trailing piece of wall and an equal size divot from another segment of wall. The red rectangle is where I tried to clip surface. Yes my rectangle was placed accurately. Surely someone has dealt with this situation before. Do I make several wall types/thickness and wrap them around? Tried the pilaster tool, works on one side. So really this is like a 3-sided pilaster. Quote Link to comment
Tom Klaber Posted September 30, 2016 Share Posted September 30, 2016 I would make an extrude or column to make the corner then have walls but up against it. Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted October 3, 2016 Vectorworks, Inc Employee Share Posted October 3, 2016 Have you tried creating a pillar like this (attached)? I drew the shape of the pillar including the wall thickness, then joined the wall to it. The shape to the upper right is a copy of what it looked like before joining. BTW: if you have trouble with the joining, try moving the ends of the wall just short of the pillar before joining them. Quote Link to comment
