object info-data window problem
recently, I have been having a problem with entering data in the object info palette. When I enter information then click enter the cursor highlights the next field of info then immediately goes back to the first field of the
record. So, instead of being able to type, hit enter and goes to the next field, I have to constantly click on the field I want, then type. Is this a bug? do you have any suggestions/solutions?
VWA 10.1.2
Mac os 10.2.6
Does this happen in a new document with a new record?
Was the file you are having the problem with a converted file from an earlier version?
If so, what version?
What record format is showing this problem>?
(Does this happen in a new document with a new record?)
The document I have was created in vw 10 but probably on system 9. It doesn't happen with all documents. I can't figure out any pattern.
Part of the documetn have been copied from documents that were converted from vw 9 to 10.
(What record format is showing this problem>?)
It is not specific to a record but to a dcument. Most of the record I am using have been created in house or are modified vw records.
yes this is how it was in vw 9, that was fixed in vw 10 so that you could use either key. My problem is not concerning which key to use, it is that the cursor alway goes back to the first field when I hit enter instead of ging to the next field in the data record.
