krw
Content Count
117 -
Community Reputation
0 NeutralAbout krw
Rank
Journeyman
Personal Information
Occupation
graduate architect
Location
california
this solutions still has the whole object acting on one class. is there a way for it to be like the stair obf where the stair, arrows, data cona be on sep classes?
depending on the size of final printing: I may want to show text on a unit plan for an apt for not for site plan.
it would be really g reat if the text for the space tools was on a seperate class or if the option was there. so that it could be easily turned off in one step when necessary.
is there still a date stamp in vw 12? if so please help me locate. I get nothing when I try to search the help manual.
that was it. since it's an auto layer I didn't even look at it. thx.
doors show fine on the design layers. when I go to the vp to print I only see the frame - views and rendering are exactly the same. does not matter if door in wall or not. they are a no show. any suggestions?
moving it would be fine if it were just one line, but I am drawing around the entire perimeter of a building. and is is not a continuous line because of doors, etc.
It would be nice if there were an option to delete orginal object when you offset a line/polygon. I am drawing a line around a wall and then offsetting it to show a watertable that is below where the wall is cut. So I don't need the original line one the offset is complete.
In additition, our graphic designer tells me that Adobe has OpenType fonts as another alternative.
They are actually .dfonts created by Apple with OS X. I guess you can get info from Apple.
Does anyone know if D fonts work in worksheets? We were having the postscript font problem in vw 10 os 10 and switched to a True Type font for worksheets. Has anyone tried using D Fonts? Thanks. VWA 10.5 OS 10.2.6
maybe there should be an option to switch the order of the x, y, l, etc boxes so that if a user prefers one method it could be that way. some days I use the length field a lot and on other days I use the x, y most.
we also had the font problem with worksheets in VW 10 when not using TT fonts but have cleared it up by switching to a TT font. About where to keep fonts, if you have multiple users on a computer it is easiest to keep fonts that are firm wide in the Harddrive >> Library >>Fonts folder and allow the User folder for user specific fonts. If you are still using OS9 you still need copies in that system folder.
'Making them tear-offs' is a great idea that needs to be added to the wish list as well as adding font formatting to the palette, simalar to ms word.
you might want to go bak to a previous file. VW can't find the class it needs to complete the task.
