Josh NZ Posted July 6, 2016 Share Posted July 6, 2016 (edited) I have a Design layer (layer 1) with 3 objects each has a different class, for the example I'll just call them class 1, 2 and 3. On another design layer I have a viewport. The viewport is classed as none. the viewport has layer 1 turned on and also class 1 and 2. If I have the navigation classes set to only show "none", if I view the viewport nothing shows. If I then turn on class 1 and 2, then the viewport shows correctly. This is against my understanding of the viewports is my understanding is that the class none should determine wether the viewport shows up or not as thats the class I have associated to the viewport. It should then be the class settings in the viewport that should determine whether or not it shows correctly. I have also ensure that the "use current document's class visibilites" box is unticked. The sheet layer viewport operate as I would expect them too. Can some one please advice me if this is a glitch or if it is how the design layer viewports are intended to work. Edited July 6, 2016 by Josh NZ Quote Link to comment
AlanW Posted July 7, 2016 Share Posted July 7, 2016 (edited) Hi, if your using design layer viewports its a bit tricky but once you sort it out it works well. You should see image as when you select the viewport. See this for how to control. http://app-help.vectorworks.net/2016/eng/index.htm#t=VW2016_Guide%2FViewports%2FChanging_the_Layer_Properties_of_Sheet_Layer_or_Design_Layer.htm&rhsearch=design%20layer%20viewports&rhhlterm=design%20layer%20viewports&rhsyns=%20 HTH Edited July 7, 2016 by Alan Woodwell Quote Link to comment
Josh NZ Posted July 7, 2016 Author Share Posted July 7, 2016 Thank Alan Ive used them right through the drawing with class overrides to show roofing as dashed etc with no fill. However these VPs are only showing up if the document classes for the roof items are turned on also. If i have the VP on class none, then in the VP class settings show the roof classes, also unticked the use doc visibilities, then the VP should show if I only have "none" turned. Quote Link to comment
AlanW Posted July 7, 2016 Share Posted July 7, 2016 you will need to go into the viewports and update the original viewport then come back out to the design layer viewport to update the final sheet. See if that fixes it. Quote Link to comment
Josh NZ Posted July 7, 2016 Author Share Posted July 7, 2016 This is before I have even setup the sheet layer viewports. The DL VPs don't have an update button so not sure what you mean sorry. Quote Link to comment
Josh NZ Posted July 7, 2016 Author Share Posted July 7, 2016 I have added a file that should hopefully show the problem I am having Quote Link to comment
AlanW Posted July 7, 2016 Share Posted July 7, 2016 (edited) If you are doing Design Layer Viewports you have a VP in your design layer and not on your sheet layer. This design layer viewport references to another design layer or sheet layer another drawing totally different. Each viewport has the OIP on right showing. Is this how you are working? Alan Edited July 7, 2016 by Alan Woodwell Quote Link to comment
Josh NZ Posted July 7, 2016 Author Share Posted July 7, 2016 Yeah that is how I am operating, will be using sheet layers later but at the moment just need to get this one item to show correctly in DL VP. Hopefully in the previous attachment it should should the issue. When you open you will find a DL with a couple of screenshots, no VP. If you turn on the other 3 classes the VP will appear, you will notice the VP is on class none, the class setting for that VP will show the box unticked to show doc visibilities. Quote Link to comment
bcd Posted July 7, 2016 Share Posted July 7, 2016 It's a bug. You are using the DLVPs correctly and your expectation of how they should work is correct. It seems that you once created a Crop Object in the Roof Services Class, and now that the VP doesn't have a Crop Object it remembers fondly that it once had and that it was classed Roof Services. So unless the Roof Services class is Visible or Greyed in your drawing the phantom Crop object will be doubly invisible ergo the Viewport will disappear. The interim solution - Create a new Crop Object in the None Class. Quote Link to comment
AlanW Posted July 7, 2016 Share Posted July 7, 2016 (edited) Josh, It appears to comes down to your slab class. See attached. If this is what you are after? Edited July 7, 2016 by Alan Woodwell Quote Link to comment
Josh NZ Posted July 7, 2016 Author Share Posted July 7, 2016 AAahhhhh that is quite a nuisance. Thanks for the info guys. Quote Link to comment
Josh NZ Posted July 7, 2016 Author Share Posted July 7, 2016 Thanks Alan. That is what Im trying to achieve, but in your file turn off the class "Roof Services" and see what happens to the VP. The response from BCD above seems to pinpoint what the issue is. Quote Link to comment
Josh NZ Posted July 7, 2016 Author Share Posted July 7, 2016 Hi BCD, I just tried another approach, I removed that class and that fixed that one instance of the VP. However when I view other VPs they still have the issue. Is the problem definitely linked to the class of a crop object? The only reason I ask is that I almost never draw in anything other than "none", it seems odd that there would be numerous crop objects at some stage with different classes. Could it someone how be linked to the visibilities of a class within the VP instead of a crop? Quote Link to comment
AlanW Posted July 7, 2016 Share Posted July 7, 2016 (edited) Seems to be an issue. To solve it highlight the viewport and untick screen objects then tick again. Now you should be able to turn off the class and the viewport will stay. Interesting but frustrating Alan Edited July 7, 2016 by Alan Woodwell Quote Link to comment
bcd Posted July 8, 2016 Share Posted July 8, 2016 Jim - you may have missed this bug? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted July 8, 2016 Vectorworks, Inc Employee Share Posted July 8, 2016 I had not seen this, apologies. Asking Tech to have a look and confirm. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted July 8, 2016 Vectorworks, Inc Employee Share Posted July 8, 2016 Confirmed, it seems that toggling the Screen Plane Objects setting in the viewport resets it, but it is still a bug and will happen again if you try to replicate it, submitting now. Quote Link to comment
Josh NZ Posted September 12, 2016 Author Share Posted September 12, 2016 This is still occurring, along with other previously mentioned bugs, is this intended to be fixed for VW2016 users, or is it to improve VW2017? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted September 12, 2016 Vectorworks, Inc Employee Share Posted September 12, 2016 I do not yet see an expected fix date on this submission. Quote Link to comment
