digitalcarbon Posted May 4, 2016 Share Posted May 4, 2016 need a script that can make this Quote Link to comment
digitalcarbon Posted May 5, 2016 Author Share Posted May 5, 2016 some eye candy resulting from the above work Quote Link to comment
Marionette Maven Marissa Farrell Posted May 5, 2016 Marionette Maven Share Posted May 5, 2016 This script is very close, might need some tweaking, but produces very similarly to what you want. Let me know if you have any comments/questions. Marissa GoldenAngle_Tool_MFarrellSolution.vwx Quote Link to comment
digitalcarbon Posted May 5, 2016 Author Share Posted May 5, 2016 (edited) very impressed, since i did mine all by trial and error might want to have a different color feature for the inside and outside rings since they are separate from each other. while i can custom select the inner ring by hand it might be a default that the inner ring is red then outer is blue etc Edited May 5, 2016 by digitalmechanics Quote Link to comment
digitalcarbon Posted May 5, 2016 Author Share Posted May 5, 2016 on second thought maybe just make a script that just makes one "donut" shape at a time. then all i do is run the script twice. that way i can make an infinite amount of rings Quote Link to comment
AlanW Posted May 5, 2016 Share Posted May 5, 2016 I Think its simply a matter of splitting the end of your network into 2 and add the attributes node, see attached. HTH You can also randomise the colours on each area or extrude them with random colours and heights. GoldenAngle_Tool_MFarrellSolution-Sep_Color.vwx Quote Link to comment
digitalcarbon Posted May 6, 2016 Author Share Posted May 6, 2016 ok thanks for all the help. after playing with it i found this out. 1. i do not need a script that makes a double ring and that i could just have a single script ring on a separate layer to make as many rings a i need. this i have done with the attached file. 2. being able to control one ring at a time has allowed me to fine tune the inputs to get the ring inside the guidelines. 3. for the inner ring, i could not find out why it did not draw the circles in the prescribed diameters... instead i had to input a large number (120) to get the inner ring to shrink down to fit in the inner guides. I'm not sure what this number does 4. having a script that makes only one ring allows me to tune the "spacing" of each ring separately. this was needed to fit the circles into the guideline spaces. 5. having a single ring script, i do not now need to separate by color since each ring is on its own layer thanks for everyones help GoldenAngle_Tool_MFarrellSolution-_single_ring.vwx Quote Link to comment
AlanW Posted May 6, 2016 Share Posted May 6, 2016 And just in case you wanted random colours here is a file. Wrappers came from either Marissa or Sarah. Quote Link to comment
Marionette Maven Marissa Farrell Posted May 6, 2016 Marionette Maven Share Posted May 6, 2016 Alan, I love your extensions on this project! The colors are VERY fun. Quote Link to comment
