attribute palette
Are there any bugs known with the attributes palette?
I have a class with fill style set to "None". In the AP, fill style is set to "By Class"
The result should be text without fill or background.
I get text with a bright red background that I have to manually change.
Why does it just behave on its own?
I don't want to have a fill associated with the text.
But now i have selected solid fill - white and moved on..
Too many of these little quirks. Time consuming to try to resolve.
Does anyone know: do typical VW users, use VW just for prelim design / models and then switch to something else for actual const. doc's?
I just can't seem to tame the beast! Not giving up yet..
Maybe I just have some issue with my installation because my windows get filled and text gets filled....my installation is just fixed on filling things. ;)
Some ideas...
1) Check that the class with the text assigned is set to use on creation
2) Check that any text styles have been assigned to the class (see Jim's post above)
3) Check the attributes default behaviour is set to "by class". see pic attached.
4) Check the organisation palette and see if there is a class in the document with a red fill. Make sure the text object is assigned to the correct class (an obvious one, I know, but if the default for the AP is set by class...)
If the above doesn't work then I would try "Remove by class setting" and then reselect "by class setting" in the AP.
otherwise I'm not sure..
