don Posted May 12, 2003 Share Posted May 12, 2003 I am using VW 8.5 and plot drawings at halfscale and blow up to full scale at a copycenter. The problem is the arrowheads on the leaders get really huge. Is there an easy way to edit them to halfsize so when I enlarge they are regular size. thanks. Quote Link to comment
Kristen Posted May 12, 2003 Share Posted May 12, 2003 If the leader lines are all on the same class, you can go to class edit and change the arrow size. It might be necessary to select the lines and change the arrow to "class type". Quote Link to comment
Guest Posted May 12, 2003 Share Posted May 12, 2003 When changing the drawing to 1/2 scale for printing purposes, are you doing ith with layer scale, scale objects command, the page setup menu or the print menu? Quote Link to comment
nowright Posted May 12, 2003 Share Posted May 12, 2003 Don, If you want to change all arrow sizes at once, first go to Organize - Custom Selection. In the Custom Selection Dialog Box first pick Select Only then click Criteria. In the Criteria Dialog Box chose "Arrow Style" - "Is" and the style you are using. Click OK. This should select all the arrows of that style. Now go to the Attribute Palette. Click the button in the lower right coner and scroll down to edit. Set Arrow Attributes Dialog Box appears. You can edit the size by changing the length. Mel Barker Highland Drafting, Inc. http://highlanddrafting.com Quote Link to comment
don Posted May 12, 2003 Author Share Posted May 12, 2003 I am using layerscale to create halfsize drawing. Quote Link to comment
CipesDesign Posted May 12, 2003 Share Posted May 12, 2003 Hi Don, There may be an easier way to get where you want to go. If you do all your drafting at actual size (ie: the size of the final full size prints) your arrowheads (and everything else) will be correct . To do your reduction, use the "scale" dialog in "page setup". Just type in 50% and be sure to change the page size. Hope this helps! Peter Quote Link to comment
defjef Posted May 13, 2003 Share Posted May 13, 2003 Cipes... Are you saying that in 8.52 there is a field in the PAGE SET UP command where you can enter a % for SCALING? Is this for any printer or just some printers? On my 2 HPs.. 930 and 1120 no such option exists. Can you clarify? Quote Link to comment
Guest Posted May 13, 2003 Share Posted May 13, 2003 Go to Flie>Page Set up. While the Page Attributes option is selected in the drop down box, you should see something called "Scale". Quote Link to comment
defjef Posted May 15, 2003 Share Posted May 15, 2003 Katie.. There is np PAGE ATTRIBTUES drop down under FILE / PAGE SET UP. The only drop downs are SIZE and SOURCE. Under properties there is a check box SCALE TO FIT,,, is this the deal? Quote Link to comment
CipesDesign Posted May 15, 2003 Share Posted May 15, 2003 defjef I haven't used 8.5.2 in a long time, but I remember that we used to use the "SCALE" box... The only thing I can imagine is that perhaps your OS & PrintDriver are different than mine were. In any event I'm sorry you can't find this feature as it is a really easy way generate reduced-size prints. Peter Quote Link to comment
Guest Posted May 15, 2003 Share Posted May 15, 2003 Jeff, What printer are you using? Some printers like Epson haev different stuff in the print dialog box, but in Page Setup, it should be relatively the same. Are you using Adobe or LaserWriter 8 ? Quote Link to comment
defjef Posted May 17, 2003 Share Posted May 17, 2003 At home I work on a PC usually with an HP 1120 and and HP 930 Windows ME. I cannot find a SAALE drawing box in page set up. But let me ask.. If I scale and entire drawing do the arrowheads and other drawing marks scale down? As I recall some "objects" do scale down.. but I ecalll arrowheads do not rescale. Does the elusive SCALE drawing option in the page set up reduce everything on the drawing to a new scale? Do drawing title objects indicate the "new" scale" or the original scale?? Quote Link to comment
ccroft Posted May 18, 2003 Share Posted May 18, 2003 defjef: The scale option is a feature of the printer driver. Different companies do it differently and it is independant of v-works or any other app. Maybe it's under "size"? It allows scaling by percentage, much like a copy machine. Anything that is sent to the printer will be printed at that setting. Pictures,text,arrowheads from v-works....anything. You will have to reset to 100% when you want "normal" printing. Quote Link to comment
P Retondo Posted May 18, 2003 Share Posted May 18, 2003 I believe that the "scale" feature of the "file -> page setup" utility was first introduced with VW v.9. It sometimes didn't work perfectly, but with v. 10 it works for me very consistently. If you are using v. 8, I think you are at the mercy of the printer driver's capabilities. Scaling with v. 10 does exactly what you would expect: it works like scaling a bitmap, scaling every element of the drawing, including lineweight. Quote Link to comment
Guest Posted May 19, 2003 Share Posted May 19, 2003 It's in VW 8 too. I have it open on my mac and looking right at it. I think it may depend on the driver/printer being used. Quote Link to comment
defjef Posted May 20, 2003 Share Posted May 20, 2003 Once again on this SCALE thing. Say I am working a layer with 1/4" scale and use a leader line. It is configured to the default size.. usually given as some dimension in inchines or whatever. I actually dont know what that means.. Does it mean that the arrow head at the 1/4" scale will measure.. for example 1/8"? OK Now I change the scale of that layer to 1/8"... Ooops the arrowheads are now very large in proportion to the rest of the drawing..they may actually be the same 1/8" but the rest of the drawing having been scaled down... the arrowheards are HUGE. The same thing happens for some symbols like drawing Name /Scale tags. WHat I typically do is work at the sscale a drawing will MOST often be plotted as and suffer thw weirdness of huge arrowheads Is there any way around THIS weirdness in 8.52? I am sorry for being stuck in 8.52... but I am waiting for a clean release which wont cause havoc in prductivity. Quote Link to comment
defjef Posted May 20, 2003 Share Posted May 20, 2003 I checked the PAGE SET up for our Network Richoh copier/printer at the office. We use it for all letter and tabloid formats. No scaling feature on the Page Setup in vw8.52 over there either. So tell me a small format printer which DOES support that PAGE SET UP feature. Quote Link to comment
matto Posted May 21, 2003 Share Posted May 21, 2003 the feature you are looking for is not really apart of Vectorworks so to speak. it's part of the operating systems printer handling. So the Page scaling in the "page Setup" is in almost all Mac's because it's something the system provides to print driver and in turn to VW. i understood that it is also in a lot of windows printer drivers, have the scale feature. from memory the cannon printers do. not sure if it's universal system feature. regards matt Quote Link to comment
ccroft Posted May 21, 2003 Share Posted May 21, 2003 iboy has said what I was trying to say before and with an added point....maybe it's a mac thing. I run v-works 8.5.2 I have printed to an apple laser,a brother laser and an HP laser all 8 1/2" X....the option is always there and not only in v-works but any and all other programs (netscape,explorer,p-shop,illustrator,quark,simpletext,bbedit,fastrack schedule,acrobat....to name some). Each of these printers uses a different driver which has been written by the printer manufacturer. On this machine the window that comes up from page-setup always looks exactly the same for a given printer(driver) in any app. I think it's safe to say it is not a v-works thing. Quote Link to comment
Guest Posted May 21, 2003 Share Posted May 21, 2003 It depneds on the driver - are you using LaserWriter 8, Adobe PS, etc. This is the reason I asked what driver is being used originally. Quote Link to comment
