James Milkey Posted May 8, 2015 Share Posted May 8, 2015 Hi All, I am running Vectorworks 2015 SP3 on a Windows machine and have encountered a little difficulty. I am drafting a light plot and it had begun to exhibit some very strange behavior. The lighting devices seem to have (for the most part) started disappearing from the viewports on the sheet layers they are in. If I double click into that viewport and go to the design layer they are all still there as I would expect. And when I am looking at the viewport in my sheet layer, when I use my mouse to zoom, they appear for a moment, only to disappear when I stop scrolling. And there are times when some appear, and then if I zoom in, they disappear. None of my symbols are 3-D and they are all very basic, under 20 2-D lines or so per symbol. Also, when I print, the lighting devices don't appear. Any thoughts? Jim Quote Link to comment
JBenghiat Posted May 8, 2015 Share Posted May 8, 2015 The issue is with 2D only symbols -- for some reason they can disappear from viewports. Add a 3D locus to your symbols (easy to do in the body symbols) and you should see them again. -Josh Quote Link to comment
James Milkey Posted May 9, 2015 Author Share Posted May 9, 2015 Hi Josh, Um. I think you blew my mind. That is a little crazy but it worked. And I must say, nothing I would have ever thought of myself. That seems like a bit of a bug that needs to be fixed. Do you know how long Vectorworks has been doing that? Just curious. Jim Quote Link to comment
JBenghiat Posted May 12, 2015 Share Posted May 12, 2015 I reported the bug with 2014. It looks like it will take some time to fix. -Josh Quote Link to comment
Kevin McAllister Posted May 12, 2015 Share Posted May 12, 2015 apparently so will posting to the forum ;-) Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted May 13, 2015 Vectorworks, Inc Employee Share Posted May 13, 2015 Yeouch, 5 repeats is a new record. Mopping up now. Quote Link to comment
Dirk Kuyk Posted May 15, 2015 Share Posted May 15, 2015 I have had a similar problem. The issue in my case was that I had deleted the 3D component of a hybrid symbol. The original symbol had been given a height (Z coordinate). So when I deleted the 3D component, VWX didn't know what to do with a 2D symbol that had a height above 0'-0". Your issue was probably similar. By adding the 3D component, even a locus, VWX knew what to do with it, and your symbols started re-appearing. Quote Link to comment
