Cadplan Architecture Posted September 27, 2014 Share Posted September 27, 2014 I need to show a back door with a side window as opposed to a side screen. The side window will only be say 1050mm high. I want to be able to have it attached to the door within the same structural opening. Is this possible? Quote Link to comment
CipesDesign Posted September 28, 2014 Share Posted September 28, 2014 Generally for this situation I simply use a door and a window very close to each other. It's the easiest way. However you might also try creating a complex window with the "door" portion set to "opening" then manually place a door into the opening. You could then select both objects and Create Symbol. Quote Link to comment
Jonathan Pickup Posted September 28, 2014 Share Posted September 28, 2014 Peter, you might be able to use the symbol of the door and window combined, by using the Use Symbol Geometry option. I haven't tried it, because I use WinDoor and it makes doors and windows in the same frame. Quote Link to comment
