Taproot Posted January 29, 2014 Share Posted January 29, 2014 Hi All, I've noted for a while now that the timber sizes within this tool are inaccurate. 8" nom. actually = 7 1/4" in reality (not 7 1/2" as per the tool). 10", 12"... all follow this standard. I looked into the "Plug-in Manager" to see if there was a way to manually update the values for the tool ... but couldn't find a way. Has anyone else been able to correct this?? Or, should I submit it as a bug? Thanks, Quote Link to comment
CipesDesign Posted January 29, 2014 Share Posted January 29, 2014 Hi Matthew, I complained about this eons ago, yet the incorrect sizes persist. As a workaround I usually just use a Custom size, set as it should be, then Duplicate and Move (or Drag) as needed? And yes, please file a (another) bug! Quote Link to comment
bc Posted January 29, 2014 Share Posted January 29, 2014 While you're at it tell them to change the end grain hatch to one of actual end grain rather than face grain... Quote Link to comment
CipesDesign Posted February 3, 2014 Share Posted February 3, 2014 Hi Matthew, and all, I revisited this just now, and it appears that the Detail Wood Cut is creating 7.25" members now, in v.2014?. Check it and see what you find... Quote Link to comment
