Flat roofs with falls
Christiaan
We need a slab or roof tool (or something else) that supports flat roof falls.
The most common being a screed laid to falls or tapered insulation (but there's also the firring strips method when using timber). Common falls are 1:40, 1:60 and 1:80.
As it stands we either have to model this with generic objects or use the slab tool and ignore the fact that the falls are not incorporated. We choose the later, which is not ideal. But the former is just an absurd non-starter on the buildings we work on.
4 answers to this question
+1 or Merge the roof and slab tools and make it possible to have slabs at an angle and individual slabs with varying thicknesses.......this way you also solve the leaning walls problem (which is still missing) and components in roofs problem (which is still missing).
Edited by Vincent C
