Christiaan Posted May 11, 2012 Share Posted May 11, 2012 We need the ability to tell Renderworks not to draw section lines through some objects. For instance 3D trees. Quote Link to comment
0 CipesDesign Posted May 11, 2012 Share Posted May 11, 2012 Put the trees in their own class, make the class invisible in the section VP. Truly simple... Quote Link to comment
0 Christiaan Posted May 11, 2012 Author Share Posted May 11, 2012 I want the trees to show, I just don't want a big fat section line around all the branches if I cut through them. Quote Link to comment
0 CipesDesign Posted May 11, 2012 Share Posted May 11, 2012 So you want an intermittent section line? Quote Link to comment
0 Christiaan Posted May 11, 2012 Author Share Posted May 11, 2012 I want to avoid this sort of carry on. Quote Link to comment
0 Christiaan Posted May 11, 2012 Author Share Posted May 11, 2012 That is one option, except I don't want to show staggered lines as my section references. And there's also a bug that causes this: http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=170132 I guess I could wait for a bug fix. And I guess I could draw a separate section marker on my key plan, but that's not very BIM. Quote Link to comment
0 starling75 Posted May 11, 2012 Share Posted May 11, 2012 That is one option, except I don't want to show staggered lines as my section references. And there's also a bug that causes this: http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=170132 I guess I could wait for a bug fix. And I guess I could draw a separate section marker on my key plan, but that's not very BIM. Or you can choose - separate cross sections + use attributes of original objects and try to fiddle with classes to make section through trees less visible ... Quote Link to comment
0 Christiaan Posted May 11, 2012 Author Share Posted May 11, 2012 Another option, thanks. What I did in the end: moved the section line Quote Link to comment
0 starling75 Posted May 11, 2012 Share Posted May 11, 2012 Another option, thanks. What I did in the end: moved the section line that was smart solution Quote Link to comment
0 starling75 Posted May 11, 2012 Share Posted May 11, 2012 (edited) Context dependent section could be the solution ... http://youtu.be/ZiMA1IAn8HU http://youtu.be/qaQFpCQS_y4 Edited May 11, 2012 by starling75 Quote Link to comment
Christiaan
10 answers to this question
