billtheia Posted September 30, 2011 Share Posted September 30, 2011 Can someone out there point me to the "New Metallic Shaders" in VW2012? I looked at the Textures_Metals Plastics Glass file and the textures appear to be exactly the same as they were in VW2011. Am I looking in the wrong place? Quote Link to comment
rDesign Posted October 6, 2011 Share Posted October 6, 2011 Bill- I read this on page 25 in the 'Fundamentals_2012.pdf' (included in the Vw2012 installer package): Improved metallic shader: Internal adjustments have been made to improve the appearance and visual effect of the Metallic reflectivity shader So it sounds like you have to make a new RW texture to see any improvements. HTH. PS. I've often wondered if Nemetschek Vectorworks bothers to update the provided RW Textures when they release a new version (which certainly should have done when they switched over to the Cinema 4D engine). Quote Link to comment
Jonathan Pickup Posted October 6, 2011 Share Posted October 6, 2011 So it sounds like you have to make a new RW texture to see any improvements. any texture that uses the Metallic shader will now be improved when you open it in Vectorworks 2012 Quote Link to comment
