tamarindi Posted November 22, 2010 Share Posted November 22, 2010 I started working on the 2011. After many years being used to work with lighting and render options in a certain way i now realize everything has changed. Lighting object do not respond as before..... Is there a manual elaborating how to use the new rendering options (beside the short movie in the "what's new.."). Quote Link to comment
tamarindi Posted November 22, 2010 Author Share Posted November 22, 2010 I'm not so sure it's inferior.... i have a feeling that it is too much of a change - and so, it must be followed with good technical help !!! Unfortunately, not all of us are located near NNA headquarters.... Quote Link to comment
VincentCuclair Posted November 22, 2010 Share Posted November 22, 2010 What settings/render modes did you use in 2010 Tami? Quote Link to comment
tamarindi Posted November 22, 2010 Author Share Posted November 22, 2010 Hi Vincent, For example: when i open a file that i started in 2010: All light objects not "lit". Although in the object info they are... Lit fog - not working i tried creating new BG and nothing.... Rendering options: I appreciate the reduction in the options. I understand now i can control the specific options in 'custom", but i don't understand the "meaning" of the different options.... In textures: Again - nice change. however, i had some "tricks" using texture that now gone (for instance: to create "lit" object i used color transparency...now it's gone. But i guess there is clever way doing that.....dont know how....) Quote Link to comment
VincentCuclair Posted November 22, 2010 Share Posted November 22, 2010 Sorry can't help with lights and fog, haven't tried those yet. Textures with transparency and/or masking will have to be adjusted to new settings, as do bump maps. In 2010 I always used ambient in both texture settings and lighting, now in 2011 I hardly ever use ambient at all, however I have started using HDRI backgrounds and indirect lighting instead. Color transparency is still there though, haven't tried it but under transparency in the texture there is a setting color......is that what you meant? Quote Link to comment
grant_PD Posted November 22, 2010 Share Posted November 22, 2010 I've found that files brought in from 2010 or earlier tend not to render as fast as fresh baked ones. I'm not sure why. The light settings seem to be a bit more sensitive. While I used to jack my lights up to 4 or 5 hundred, now I'm keeping them down around the hundreds. Lit fog works for me, but it doesn't show up until the end of the rendering. So you won't see it until you hear the "ding" of a done rendering. The new texture shaders are cryptic to say the least. I'm not sure how I will ever remember what they do, as their name gives me no help at all. But there are some nice features. Glow is what you're looking for in reflectivity to make lit objects. And they will even emit light. Which brings me to my last point. The greatest improvement in the rendering engine is the indirect lighting option. Turn it on in the lighting menu. Yes it takes longer but the results are worth it. Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted November 22, 2010 Vectorworks, Inc Employee Share Posted November 22, 2010 Take a look here for some information on translating rendering... http://www.vectorworks-training.co.uk/Buy_Vectorworks/Renderworks.aspx There's a file you can download at the bottom of the page. Quote Link to comment
tamarindi Posted November 22, 2010 Author Share Posted November 22, 2010 Vincent - My point exactly: some explanation on the "logic" of HDRI and new texture is exactly what i need..... and no where to find. Grant - I think that you have a point. Imported light objects are not working properly. It's ok to create new ones....but it could be nice that NNA would mention it before we struggle.... Shaders are cryptic !! exactly. no idea how to handle it now. Again - a manual would be nice..... And no...the "help" doesn't do the work this time. there are to many variants... Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted November 22, 2010 Vectorworks, Inc Employee Share Posted November 22, 2010 Lit fog works fine... you just need to enable it in the lights. You may find that as you have a 32 bit machine, you will not see the benefits of the new Renderworks... Quote Link to comment
tamarindi Posted November 22, 2010 Author Share Posted November 22, 2010 Take a look here for some information on translating rendering... http://www.vectorworks-training.co.uk/Buy_Vectorworks/Renderworks.aspx There's a file you can download at the bottom of the page. WOW!!! Tamsin - you are the BEST !!! covering everything..... Thanks :-))))))) Quote Link to comment
