James Russell Posted May 11, 2010 Share Posted May 11, 2010 Just wondering if anyone can help me with the SetWSCellFormula command. I was trying this: Procedure Test; VAR FL :String; SN,TN :Integer; WSH :Handle; Begin SN:=1; TN:=10; WSH:=CreateWS(Concat('Test',Date(2,1)),10,5); While SN<=TN Do Begin Case SN of 1: FL:='A'; 2: FL:='B'; 3: FL:='C'; 4: FL:='D'; 5: FL:='E'; 6: FL:='F'; 7: FL:='G'; 8: FL:='H'; 9: FL:='I'; 10: FL:='J'; End; SetWSCellFormula(WSH,SN,0,SN,0,'=Database((R IN [''TestRecord'']) & ([''TestRecord''.''FieldA'']=FL))'); SN:=SN+1; End; End; Run (Test); So the loop through seems to work fine although I only know this because I get 10 error message saying invalid factor. I've been struggling a lot with the SetWSCellFormula line, it works supremely well with the =database(R IN [''testrecord'']) by itself but I think I've broken it with a lookup with a variable. Thanks in advance, especially if you read this far! James Quote Link to comment
Pat Stanford Posted May 11, 2010 Share Posted May 11, 2010 You can't use variables directly in the criteria. You need to use the Concat function to make a single string that is exactly the criteria you want and then use that string as the criteria. MyCriteria:=Concat('=Database((R IN [''TestRecord'']) & ([''TestRecord''.''FieldA'']=FL))'); SetWSCellFormula(WSH,SN,0,SN,0,MyCriteria); I have not looked at this extremely closely, but make sure all of your quotes and escaped quotes are correct. Quote Link to comment
Miguel Barrera Posted May 11, 2010 Share Posted May 11, 2010 Expanding on Pat's observations, these are my 2 cents which are based on a working script. MyCriteria:= Concat('=DATABASE((''TestRecord''.''FieldA''=', FL, '))'); SetWSCellFormula(WSH,SN,0,SN,0,MyCriteria); You do not need 'R IN [''TestRecord'']' because the second argument implies FieldA is in TestRecord. Make sure you type 2 single quotes '' and not just a double quote " Quote Link to comment
Miguel Barrera Posted May 11, 2010 Share Posted May 11, 2010 I just realized that the default font does not help in showing the two single vs double quotes. So here it is again: [font:Courier New] Expanding on Pat's observations, these are my 2 cents which are based on a working script. MyCriteria:= Concat('=DATABASE((''TestRecord''.''FieldA''=', FL, '))'); SetWSCellFormula(WSH,SN,0,SN,0,MyCriteria); You do not need 'R IN [''TestRecord'']' because the second argument implies FieldA is in TestRecord. Make sure you type 2 single quotes '' and not just a double quote " [/font] Quote Link to comment
James Russell Posted May 11, 2010 Author Share Posted May 11, 2010 Thanks guys, exactly the solution I needed. Cheers, James Quote Link to comment
Assembly Posted May 14, 2010 Share Posted May 14, 2010 James What does this do?. What is your application?. Quote Link to comment
James Russell Posted May 17, 2010 Author Share Posted May 17, 2010 I'm currently making a worksheet generator. There is a style which has been adopted at my current workplace since vectorworks 10 or so and I'm attempting to replicate it into 2010. Fingers crossed I can sort all the quirks out. J Quote Link to comment
