Structure for Variable within Lookup.
Just wondering if anyone can help me with the SetWSCellFormula command. I was trying this:
Procedure Test;
VAR
FL :String;
SN,TN :Integer;
WSH :Handle;
Begin
SN:=1;
TN:=10;
WSH:=CreateWS(Concat('Test',Date(2,1)),10,5);
While SN<=TN Do
Begin
Case SN of
1: FL:='A';
2: FL:='B';
3: FL:='C';
4: FL:='D';
5: FL:='E';
6: FL:='F';
7: FL:='G';
8: FL:='H';
9: FL:='I';
10: FL:='J';
End;
SetWSCellFormula(WSH,SN,0,SN,0,'=Database((R IN [''TestRecord'']) & ([''TestRecord''.''FieldA'']=FL))');
SN:=SN+1;
End;
End;
Run (Test);
So the loop through seems to work fine although I only know this because I get 10 error message saying invalid factor. I've been struggling a lot with the SetWSCellFormula line, it works supremely well with the =database(R IN [''testrecord'']) by itself but I think I've broken it with a lookup with a variable.
Thanks in advance, especially if you read this far!
James
You can't use variables directly in the criteria. You need to use the Concat function to make a single string that is exactly the criteria you want and then use that string as the criteria.
MyCriteria:=Concat('=Database((R IN [''TestRecord'']) & ([''TestRecord''.''FieldA'']=FL))');
SetWSCellFormula(WSH,SN,0,SN,0,MyCriteria);
I have not looked at this extremely closely, but make sure all of your quotes and escaped quotes are correct.
Expanding on Pat's observations, these are my 2 cents which are based on a working script.
MyCriteria:= Concat('=DATABASE((''TestRecord''.''FieldA''=', FL, '))');
You do not need 'R IN [''TestRecord'']' because the second argument implies FieldA is in TestRecord.
Make sure you type 2 single quotes '' and not just a double quote "
I just realized that the default font does not help in showing the two single vs double quotes. So here it is again:
[font:Courier New]
Make sure you type 2 single quotes '' and not just a double quote " [/font]
