Christiaan Posted November 25, 2009 Share Posted November 25, 2009 Can the new singing dancin' stair tool do a balustrade as the attached image? That is, with the bottom rail of the balustrade coming down below the stair nosing. Quote Link to comment
gScott Posted November 26, 2009 Share Posted November 26, 2009 if it can, it shouldn't be allowed to, makes my eyes hurt sorry Quote Link to comment
Kool Aid Posted November 27, 2009 Share Posted November 27, 2009 Can the new singing dancin' stair tool do a balustrade as the attached image? That is, with the bottom rail of the balustrade coming down below the stair nosing. At least I can't get it to do this. I have started my own wish list for the stair tool, this being the 3rd or 4th item entered! The next one was a hand rail fixed to wall, as per your image, too? I intend to send the list directly to Computerworks (since I have a direct contact with them) and I'd be more than happy to include other peoples' notions (if I deem them to be relevant?) Overall, I am reasonably happy with the new stair tool, but obviously there's quite a learning curve. Quote Link to comment
Christiaan Posted November 27, 2009 Author Share Posted November 27, 2009 if it can, it shouldn't be allowed to, makes my eyes hurt In the UK it's called complying with the building regs. Park K, paragraph 1.29: Except on stairs in a building which is not likely to be used by children under 5 years the guarding to a flight should prevent children being held fast by the guarding. The construction should be such that: a. a 100mm sphere cannot pass through any openings in the guarding Quote Link to comment
gScott Posted November 27, 2009 Share Posted November 27, 2009 christiaan building regs are fine, there are many ways of achieving compliance balancing regulations, material requirements, costs + not least, aesthetic design; it's called architecture i am not attacking you, it is, in my opinion, just one fugly railing, particularly the totally random relationship of the verticals to the treads but i suppose, on reflection, we shouldn't let software start having aesthetic parameters, click here for: gorgeous, banal, fugly. el cheapo, just affordable, insane Quote Link to comment
Christiaan Posted November 27, 2009 Author Share Posted November 27, 2009 Regardless gideon, you've hijacked the thread. The fact is every stair we do with an attached guarding and no modification to the stair needs to go below the nosing is some fashion to meet building regs. Which is the vast majority of what we do. Quote Link to comment
Kool Aid Posted November 27, 2009 Share Posted November 27, 2009 I'm sure that design of eg. Public Housing in South Africa is entirely driven by Architecture. Notwithstanding: the fundamental requirement, as expressed by Christiaan, applies also to Architectural solutions: the balustrade/railing/guard (whatever its configuration) needs to go where the Architect wants it to go. In one of my old stock designs, there is a glass panel that follows the structural bottom of the concrete stair run (? 50), is at least 1200 high and has a hand rail at 900. Quote Link to comment
gScott Posted November 28, 2009 Share Posted November 28, 2009 dear petri remaining off topic, "public housing" in south africa is barely driven by 'construction' let alone "Architecture". district 9 will give you a fair impression of the vast majority of south african accommodation, 'nigerians' + aliens excluded... definitely more preferable, your stock design, than what has been illustrated as, presumably, superior euro design. sorry, keep forgetting that that uk is still trying furiously to remain non-euro. but then again, i know 'bugger all' about europe, thomas, milkwood etc... presume you left enough space between flights to get the bolts in to hold the glass, we africans have enormous fists and getting the spanner in at the top + bottom can be a pain in the whatsit ok, enough... kisses kisses Quote Link to comment
gScott Posted November 28, 2009 Share Posted November 28, 2009 christiaan ok, enough of my flippancy. i don't think that a PIO could possibly anticipate the myriad ways people will try to do a balustrade. if i could do a balustrade the same way twice i could make more money with standardised details, but real life, my clients, and i aren't like that. the best thing i do with with the PIO hand rail is to set it at a height of 2100mm to check headroom in section VP's, which, odd as it sounds is actually extremely valuable to me. we do very tight, chi-chi projects where every cm counts + not screwing up the headroom is an issue, every time. so i don't think we can expect PIO flexibility in every aspect... grovelingly yours gideon Quote Link to comment
Christiaan Posted November 30, 2009 Author Share Posted November 30, 2009 i don't think that a PIO could possibly anticipate the myriad ways people will try to do a balustrade. All I?m asking for is the ability to achieve building regs compliance with a common stair configuration in the UK. Not much to ask for I would have thought. Any any case I think you?re actually wrong about what to expect from PIOs. A sufficiently abstracted graphically controlled PIO should be able to do anything one likes. The problem is these dialogue box driven PIOs which have to make a myriad to assumptions about your starting point. Check out Cadimages Tools' Stair Builder for the direction I think PIOs will need to go in: http://www.cadimagetools.com/resources/movieView.aspx?id=152 http://www.cadimagetools.com/resources/movieView.aspx?id=152 Quote Link to comment
Kool Aid Posted November 30, 2009 Share Posted November 30, 2009 All I?m asking for is the ability to achieve building regs compliance with a common stair configuration in the UK. Not much to ask for I would have thought. Let the record show that similar conditions exist in all civilized countries I know. I don't have any experience with South Africa, though. Is it one? It is in fact curious why our German friends don't know this. Quote Link to comment
Kool Aid Posted November 30, 2009 Share Posted November 30, 2009 (This is a separate issue in some respects.) Whilst it is certainly true that 3D-modelling of mundane stairs (public housing, separate fire exits of high-rises etc.) is theoretically nonsensical, we have a process issue here. In many legislations, permit application drawings are required to include sections of all fire exit stairs, to establish headrooms, total heights of flights etc. Surely we are entitled to expect that a Section Viewport can, substantially, be used for this? Here outside South Africa, we don't do drafting any more. Quote Link to comment
brudgers Posted November 30, 2009 Share Posted November 30, 2009 if it can, it shouldn't be allowed to, makes my eyes hurt In the UK it's called complying with the building regs. Park K, paragraph 1.29: Except on stairs in a building which is not likely to be used by children under 5 years the guarding to a flight should prevent children being held fast by the guarding. The construction should be such that: a. a 100mm sphere cannot pass through any openings in the guarding There are simpler methods of compliance. Some involve stringers. Looking at the way in which the mounting plates overlap the double lines in your sketch, I'm not sure it's reasonable to expect that NNA could anticipate your particular solution. Quote Link to comment
Kool Aid Posted November 30, 2009 Share Posted November 30, 2009 Let the record show that, according to brudgers, it is easier to change an entire construction industry than a PIO. Quote Link to comment
brudgers Posted November 30, 2009 Share Posted November 30, 2009 The entire construction industry? According to whom? Your wife, Morgan Fairchild? Quote Link to comment
Jonathan Pickup Posted November 30, 2009 Share Posted November 30, 2009 can we please get this discussion back on topic please? Quote Link to comment
Christiaan Posted December 1, 2009 Author Share Posted December 1, 2009 There are simpler methods of compliance. Contractor: You want to add a nib to the sides of the precast concrete stair? Christiaan: Yes. Contractor: Why can't we just do it the way we normally do? Christiaan: Well we're trying to do this whole BIM thing. Heard of that? Yeah, well, it's all in 3D right, and my software can't really draw the stair we normally do, not unless we go to great effort modelling it manually, so we thought better just to change the way we do the stair. Anyway, the guys on the forum said it was simpler. Contractor: Oh, okay, that makes perfect sense, we'll get right to it. P.S. sorry Jonathan, couldn't resist. Quote Link to comment
brudgers Posted December 1, 2009 Share Posted December 1, 2009 Christiaan: Well we're trying to do this whole BIM thing. Heard of that? Yeah, well, it's all in 3D right, and my software can't really draw the stair we normally do, not unless we go to great effort modelling it manually, so we thought better just to change the way we do the stair. Anyway, the guys on the forum said it was simpler. I want Vectorworks to design a parking garage in the style of Thomas Jefferson. Quote Link to comment
Christiaan Posted December 1, 2009 Author Share Posted December 1, 2009 I could show you a thousand examples of the stair I've described (if I could be bothered). Show me one example of a parking garage in the style of Thomas Jefferson. Quote Link to comment
Kool Aid Posted December 1, 2009 Share Posted December 1, 2009 Christiaan: Well we're trying to do this whole BIM thing. Heard of that? Yeah, well, it's all in 3D right, and my software can't really draw the stair we normally do, not unless we go to great effort modelling it manually, so we thought better just to change the way we do the stair. Anyway, the guys on the forum said it was simpler. I want Vectorworks to design a parking garage in the style of Thomas Jefferson. Dear me: the Parking Garage PIO is missing from my workspace! Quote Link to comment
brudgers Posted December 1, 2009 Share Posted December 1, 2009 I could show you a thousand examples of the stair I've described (if I could be bothered). Show me one example of a parking garage in the style of Thomas Jefferson. The Palladio Software can do it. Just ask the late Frank Pepper. Quote Link to comment
Kool Aid Posted December 1, 2009 Share Posted December 1, 2009 Including disabled parking? Remarkable! Quote Link to comment
