Anthony Reilly Posted August 20, 2009 Share Posted August 20, 2009 Hi All, Switching from CAD to VW ... have set grid snap to 1' (ref grid same) and the snap grid is highlighted in the Constraints menu, but I can't get the cursor to snap to the grid. Suggestions please. Thanks Guy Quote Link to comment
Jonathan Pickup Posted August 21, 2009 Share Posted August 21, 2009 is this in 2D or 3D? are you drawing something, or just moving the mouse around the screen? Quote Link to comment
Anthony Reilly Posted August 21, 2009 Author Share Posted August 21, 2009 I'm in Top/Plan view and it doesn't matter weather I am drawing or just moving the cursor around the screen. It won't snap to the grid. Thanks, Guy Quote Link to comment
michaelk Posted August 21, 2009 Share Posted August 21, 2009 The curser itself doesn't "jump" to the next grid snap, but if you watch the curser position cues in the lower right corner, you will see that it is jumping to the grid snaps. Try drawing a rectangle with the grid snap on and the view zoomed in enough and you will see that the rectangle corner jumps to the next grid snap ahead of the curser. You wouldn't want the curser to jump between snaps, because you often want to snap to or acquire a smart point that isn't on a grid snap. hth michaelk Quote Link to comment
Anthony Reilly Posted August 21, 2009 Author Share Posted August 21, 2009 Hmm. The saga continues. While drawing rectangles or moving a rectangle (2D or 3D) it did not snap to the designated 1' increment. This is a simple thing, but I would use it a lot. I know there's something I must have missed in the settings. Thanks for the suggestions, Guy Quote Link to comment
michaelk Posted August 21, 2009 Share Posted August 21, 2009 What version of VW are you using? I just did a test w/ VW 2009. When dragging rectangle around, it snapped to the grid as expected - unless, of course, the curser was following one of the faces of the rectangle. In that case it was snapping to an object. Turning off the Snap to Object constraint (but leaving the Snap to Grid on) made the rectangle only drag in grid snap units. michaelk Quote Link to comment
Anthony Reilly Posted August 21, 2009 Author Share Posted August 21, 2009 Michaelk, Thanks for the inspiration! I went into SmartCursor Settings and turned off "Acquire Smart Point if the mouse stops for: .5 seconds." I can now snap to the grid and still align with other objects. Thanks again, Guy Quote Link to comment
michaelk Posted August 21, 2009 Share Posted August 21, 2009 Glad you got it working. You can also use ESC to "clear" the smart points if you accidently hovered over the wrong point for 1/2 a second. I use smart points all the time and I find it easier to clear unwanted points than to use the T key to manually acquire them. michaelk Quote Link to comment
Bruce Kieffer Posted September 2, 2009 Share Posted September 2, 2009 Sorry to jump in here late, but I can't move a complex object and keep it on the grid without turning off snap to object. Disabling smart points does not help. My solutions have been to turn off snap to object while moving those objects, or make the move by entering data in the floating data field, or use the move command, which I dislike because I can never remember which way the object will move based on + or - entries. Any other options you can think of? Quote Link to comment
michaelk Posted September 2, 2009 Share Posted September 2, 2009 Bruce Does Shift-Command-Arrow do what you are looking for? michaelk Quote Link to comment
Bruce Kieffer Posted September 2, 2009 Share Posted September 2, 2009 Bruce Does Shift-Command-Arrow do what you are looking for? michaelk Yes and no. It's cool that Shift-Command-Arrow moves an object one grid increment, something I never used before, but will in the future. I grab and drag objects, that's what I'm use to doing. Quote Link to comment
Ray Libby Posted September 2, 2009 Share Posted September 2, 2009 Instead of trying to drag objects a set distance use the Move command. Ctrl+M. Quote Link to comment
