tomm11 Posted June 3, 2009 Share Posted June 3, 2009 How do I increase the line weight for the tub-shower hybrid object. The weight is now set at 2 I'm using the 2008 version Thanks Quote Link to comment
HP Sauce Posted June 3, 2009 Share Posted June 3, 2009 If you are using Auto-Classing you ought change it via the Class preferences (the class it is on depends on the naming system you chose; "Plumbing-Fixtures" for example). To do this, right-click on the class you wish to edit within your navigation palette and select Edit, then amend the settings for the class. If you are not using auto-classing, the fixture is not on a class, or you wish for it to be different than the object's current class settings dictate, select the object and, using the Attributes palette, change the settings as desired. Quote Link to comment
bcd Posted June 4, 2009 Share Posted June 4, 2009 You may find the symbol is comprised of objects with various classes. You could edit the 2d element of the hybrid symbol from the Resource Browser and see if this helps. Quote Link to comment
Cloud Hidden Posted June 5, 2009 Share Posted June 5, 2009 Or edit the 2d element in your file and change the line weights (double click the object). Quote Link to comment
