Line weight tub-shower
If you are using Auto-Classing you ought change it via the Class preferences (the class it is on depends on the naming system you chose; "Plumbing-Fixtures" for example). To do this, right-click on the class you wish to edit within your navigation palette and select Edit, then amend the settings for the class.
If you are not using auto-classing, the fixture is not on a class, or you wish for it to be different than the object's current class settings dictate, select the object and, using the Attributes palette, change the settings as desired.
