barnes2000 Posted May 28, 2009 Share Posted May 28, 2009 I think this is a display issue. When ever I extrude a circle, it becomes an octagon. How do I keep the curvature of the circle after extruding it? Quote Link to comment
michaelk Posted May 28, 2009 Share Posted May 28, 2009 VectorWorks>Preferences>3D Tab>3D conversion res>very high. hth michaelk Quote Link to comment
Pat Stanford Posted May 28, 2009 Share Posted May 28, 2009 Check your Vectorworks Preferences. Edit Tab - 2D conversion res: 3D Tab - 3D conversion res: If these are set to low, then you will get an octagon. The higher you set them the more vertices, the more faces and the smoother the extrusion. The other possibility is to use the Cylinder tool from the 3D toolset. Quote Link to comment
