Help with Display Settings
Check your Vectorworks Preferences.
Edit Tab - 2D conversion res:
3D Tab - 3D conversion res:
If these are set to low, then you will get an octagon. The higher you set them the more vertices, the more faces and the smoother the extrusion.
The other possibility is to use the Cylinder tool from the 3D toolset.
