Text Size Control
Assembly
Text size is controlled by layer.
Is there a function to set absolute text size.
What I'm thinking is creating a PIO that will be viewed at 2 scales
1-50 & 1-5 and using the Class to control visibility.
Say
Nameclass(Notes-Scale5)
Nameclass(Notes-Scale50)
For this to work I need to control the absolute size of the text regardless of the layer scale it is inserted on.
The typical way to do this is to set your text sizes so that you canmultiply it by the layer scale so it will be the correct size. Something like:
pioTextSize := ((GetObjectVariableReal(pioHandle, 17)/GetLScale(GetLayer(pioHandle))) * 72) / 25.4;
This was taken from a Vectorscript list post by Charles Changeler on 1 May 2007. The Subject was Re: Text size of PIOs.
Procedure textpio;
Var
layerscalestring:string;
PIOrecordhandle:handle;
pioHandle:handle;
PIOwallhandle:handle;
pioTextSize:real;
PIOname,
pioText: String;
PIOlayerscale:integer;
BEGIN;
IF getcustomobjectinfo(PIOname,PIOHandle,PIOrecordhandle,PIOwallhandle)=TRUE
THEN
BEGIN;
PIOlayerscale:=getlscale(PIOHandle);
layerscalestring:=num2str(5,PIOlayerscale);
TextOrigin(0,0);
textsize(300mm/PIOlayerscale);
BeginText;
Concat
(Ptext,'This is the scale 100 size','
',layerscalestring)
EndText;
textsize(75mm/PIOlayerscale);
BeginText;
Concat
(Ptext,'This is the scale 25 size')
EndText;
hmove(lnewobj,0,-50);
textsize(15mm/PIOlayerscale);
BeginText;
Concat(Ptext,
'This is the scale 5 size')
EndText;
hmove(lnewobj,0,-70);
END;
END;
run(textpio);
Procedure textpio;
Var
layerhandle:handle;
pioHandle:handle;
pioTextSize:real;
PIOname,
pioText: String;
textheight:real;
scale1:real;
scale2:real;
scale3:real;
classstring1,
classstring2,
classstring3:STRING;
BEGIN;
classstring1:=Concat('Note-Text-',num2str(0,pscale1));
classstring2:=Concat('Note-Text-',num2str(0,pscale2));
classstring3:=Concat('Note-Text-',num2str(0,pscale3));
textheight:=ptextheight;
THEN
BEGIN;
layerhandle:=getlayer(PIOHandle);
PIOlayerscale:=getlscale(layerhandle);
TextOrigin(0,0);
Nameclass(classstring1);
textsize(textheight*pscale1/PIOlayerscale);
BeginText;
Ptext
EndText;
Nameclass(classstring2);
textsize(textheight*pscale2/PIOlayerscale);
BeginText;
Ptext
EndText;
textsize(textheight*pscale3/PIOlayerscale);
Nameclass(classstring3);
BeginText;
Ptext
Endtext;
END;
END;
run(textpio);
