j.christ Posted June 8, 2008 Share Posted June 8, 2008 (edited) Problem occurs when inserting windows in raking walls. Issue is when the sill level is higher than the lowest point of the raking wall. VW display seems to be ok using the VW13 windows & doors, but i'd rather use the WDoor13 system. I believe that when VW13 is processing the surfaces for rendering it is incorrectly doing so. Anyone else have similar problems. Edited June 8, 2008 by j.christ Quote Link to comment
M5d Posted June 10, 2008 Share Posted June 10, 2008 So you're back! You should try emailing Julian Carr direct at OzCad. He addresses WinDoor problems & inquires very quickly. Quote Link to comment
mike m oz Posted June 10, 2008 Share Posted June 10, 2008 I've been able to replicate the problem. A quick and dirty solution would be to split the wall at the left jamb of the window unit and then reshape the tops. The remaining section of wall will then behave as it should. Quote Link to comment
j.christ Posted June 19, 2008 Author Share Posted June 19, 2008 Mike...thanks for the temporary solution...but this is just not right! Quote Link to comment
D Wood Posted June 19, 2008 Share Posted June 19, 2008 M5d Not only risen, but practising architecture in the Bay of Islands ........ Paradise indeed - especially if you've got a boat. Quote Link to comment
