cwailes Posted February 21, 2008 Share Posted February 21, 2008 Does anyone have any suggestions on creating kitchen counters? There are only a couple listed in the forum. Quote Link to comment
CipesDesign Posted February 21, 2008 Share Posted February 21, 2008 In addition to the counter tops that belong to the cabinet plug-in(s), there is a counter top tool. It works adequtely for simple shapes. For complex shapes you can make your own hybrid symbols. Start with a polygon in top/plan view. Duplicate it and then extrude. Go to side view and move the extrude up to it's correct "z" height. Go back to top/plan and select both objects. Go to MODFIFY>CREATE SYMBOL... Quote Link to comment
mike m oz Posted February 21, 2008 Share Posted February 21, 2008 You can also use Floor objects. These have the advantage they can be modified using Add Surface and Clip Surface. The Cabinet objects can then be used minus the Counter tops Quote Link to comment
CipesDesign Posted February 21, 2008 Share Posted February 21, 2008 The problem with floor objects is their inability to have textured sides. This has been a bummer forever... Quote Link to comment
mike m oz Posted February 21, 2008 Share Posted February 21, 2008 Good point Peter. I rarely model them with textures so had overlooked that. What we really need is an object that can be modified like a floor object can, but will accept textures to all edges. Quote Link to comment
Dieter @ DWorks Posted February 21, 2008 Share Posted February 21, 2008 Or you can use the space object. I always use a space instead of a floor when it need to be textured on the side Quote Link to comment
islandmon Posted February 21, 2008 Share Posted February 21, 2008 i use Walls for everything .. they allow Class control of Lt&Rtside¢er textures... they are Hybrid ... and they actually work as advertised ; ) Quote Link to comment
brudgers Posted February 21, 2008 Share Posted February 21, 2008 If only walls would allow compound cross sections...like base boards, chair rails, etc. It's one of the things I really miss from ADT. Quote Link to comment
islandmon Posted February 21, 2008 Share Posted February 21, 2008 If only walls would allow compound cross sections...like base boards, chair rails, etc. Since Walls don't allow for Variable profiles... ExrtudeAlongPath is the best option. Quote Link to comment
